BDI-2000 was Re: Internal_errors_What_happened = 18? (RTEMS_CALLED_FROM_ISR)
Leon Pollak leonp at plris.com
Mon Feb 2 14:11:01 UTC 2009
On Monday February 2 2009, Joel Sherrill wrote:
> If I remember this all correctly, the BDI-2000 speaks regular
> gdb remote protocol.  You can use the powerpc-rtems gdb
> binary and connect something like this:
> target remote IP:PORT
> You might want to do a "load" command to get the image
> to the target.
> But this should be in your bdi documentation.  Perhaps someone
> with one currently setup can be of more direct use.
I am working just now with BDI2000 on MPC8260.
Yes, Joel, you are right.
I will be glad to help, if I can.
Leon
