help: failed to use qemu
Tue Feb 10 18:43:12 UTC 2009
I am happy to report that the if_fxp (Intel i8255x driver)
works with QEMU with any of the following NIC models
specified:
i82551
i82557b
i82559er
That is in addition to the ne2k_isa we historically used.
That leaves pcnet, ne2k_pci,  pcnet, and rtl8139 as the
remaining NICs simulated for i386 qemu that we
don't support.
--joel
Joel Sherrill wrote:
>>> Daron Chabot wrote:
>>>> On 10-Feb-09, at 7:02 AM, PowerMan wrote:
>>>>> I do it as the follow steps:
>>>>> 1. download QEMU from  http://bellard.org/qemu/qemu-0.9.1-i386.tar.gz
>>>>> 2. install it
>>>>>     tar xfz qemu-0.9.1-i386.tar.gz -C /
>>>>> 3. download rtems floppy image from ftp server :
>>>>>     ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-boot.img
>>>>> 4. download ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-grub.cfg
>>>>>     and copy it to my root directory /
>>>>> 5. mkdir /capture
>>>>>    cp hello.exe /capture/capture.exe
>>>>> 6. run qemu
>>>>>     qemu -fda rtems-boot.img -boot a -hda /dev/sda
>>>>> but the capture.exe (which is actually helloworld I build with
>>>>> rtems-4.7.3) does not run as I excepted.
>>>>> This capture.exe could run on my host by modifying /boot/grub/menu.lst
>>>>> I type the following commands in grub:
>>>>> grub> set root=(hd0,0)
>>>>> grub> set kernel=/capture/capture.exe
>>>>> grub> boot
>>>>> then grub told me:
>>>>> error: no loaded kernel
>>>>> grub> multiboot /capture/capture.exe
>>>>> then grub told me:
>>>>> error: Couldn't open file
>>>>> Could somebody help me?
>>>>> My host is openSUSE 11.1, my disk information is:
>>>>> /dev/sda1              3091312    516528   2417752  18% /
>>>>> udev                    252876      5428    247448   3% /dev
>>>>> /dev/sda8              3605268    153972   3268160   5% /home
>>>>> /dev/sda7              1130540    221192    851920  21% /tmp
>>>>> /dev/sda9              6412052   3541120   2545216  59% /usr
>>>>> /dev/sda6              1130540    193556    879556  19% /var
>>>>> grub> ls
>>>>> then grub told me:
>>>>> (fd0) (hd0) (hd0,0) (hd0,4) (hd0,5) (hd0,6) (hd0,7) (hd0,8)
>>>>> they didn't match my host disk partition number
>>>> Grub is not a requirement for using Qemu, and may actually
>>>> complicate  the matter.
>>>> I've had success with variations on the following command:
>>>>     qemu -no-reboot -m 128 -boot n -tftp
>>>> /path/to/exe/parent/directory - bootp /yourRtemsApp.exe -serial stdio
>>> I can make this work for hello and ticker but not for networked
>>> applications.  Do you have a way to run networked applications
>>> this way?
>> Nope. Sorry. I haven't found the magic qemu-cmdline/network-config combo
>> yet. It has been awhile since I was playing around with Qemu and
>> networked RTEMS apps, but I recall that one of the problems for me was
>> that mac os x has no concept of tun/tap interfaces (at least not
>> natively; there is a third-party driver, but I had no luck with it).
>> I'll revisit things tonight and see if I figure anything out.
> I can run networked applications just not after using tftp/bootp.
> I have to boot them from a floppy.
> I am curious if the Intel FXP driver works on qemu.  :)
>>> I am trying to have some demos for a GSoC/RTEMS presentation
>>> on Monday at University of Tennessee at Chattanooga and was
>>> actually trying this out today. :)
>>> --joel
