help: failed to use qemu
Wed Feb 11 14:50:44 UTC 2009
Daron Chabot wrote:
> I've had some limited success with the Etherboot/TFTP approach to
> launching RTEMS networking apps with Qemu. Specifically, Till's
> GeSys-2.4 (using TFTP FS). However, I'm getting ne2000 error messages
> (see Qemu output below).
I've never seen this with my tests on qemu ne2000.  My
network configuration file for qemu is in the network-demos
CVS modules as "networkconfig-qemu.h".
PowerMan... I put some notes a few sample executables
in ftp under /pub/rtems/people/joel/qemu.  I think the
console is left directed to VGA on these since -serial stdio
does not work on MS-Windows.
I am trying to have a configuration to do a demo with
at a university next Monday.
> Command line:
> 	qemu -no-reboot -m 128 -boot n -tftp ./o-optimize -bootp /rtems.exe -
> serial stdio
> 		-net nic,macaddr=00:ab:cd:ef:12:34 -net user,hostname=foo.bar
> RTEMS network config:
> static char ethernet_address[6] = { 0x00, 0xab, 0xcd, 0xef, 0x12,
> 0x34 };
> static struct rtems_bsdnet_ifconfig netdriver_config[1] = {{
>      NIC_NAME,   /* name */
>      NIC_ATTACH, /* attach function */
>      0,          /* link to next interface */
>      FIXED_IP_ADDR,
>      FIXED_NETMASK,
>      ethernet_address,
>      irno:9,
>      port:0xc100
> struct rtems_bsdnet_config rtems_bsdnet_config = {
>      &netdriver_config[0],         /* Network interface */
> #ifdef NIC_NAME
>      RTEMS_DO_BOOTP,/* Use BOOTP to get network configuration */
> #else
>      0,                        /* Use BOOTP to get network
> configuration */
> #endif
>      NETWORK_TASK_PRIORITY,    /* Network task priority */
> #if   defined(MEMORY_CUSTOM)
>      MEMORY_CUSTOM,
> #elif defined(MEMORY_SCARCE)
>      100*1024,                 /* MBUF space */
>      200*1024,                 /* MBUF cluster space */
> #elif defined(MEMORY_HUGE)
>      2*1024*1024,              /* MBUF space */
>      5*1024*1024,              /* MBUF cluster space */
> #else
>      180*1024,                 /* MBUF space */
>      350*1024,                 /* MBUF cluster space */
> #endif
> Qemu stdout:
> djc at TooLBox--> qemu -no-reboot -m 128 -boot n -tftp ./o-optimize -
> bootp /rtems.exe -serial stdio -net nic,macaddr=00:ab:cd:ef:12:34 -
> net user,hostname=foo.bar2009-02-11 08:13:12.358 i386-softmmu[27925] KO
> Welcome to RTEMS GeSys
> This system $Name: GeSys_2_4 $ was built on 20090210CST22:02:10
> $Id: init.c,v 1.43 2008/03/22 20:36:13 guest Exp $
> Installing TIOCGWINSZ line discipline: ok.
> To skip initialization, press a key now...
> network device 'ne1' <00:AB:CD:EF:12:34> initialized on port 0xC100,
> irq 9
> bootpc_init: using network interface 'ne1'
> bootpc hw address is 0:ab:cd:ef:12:34
> My ip address is 10 .0 .2 .15
> Ignoring BOOTP/DHCP option code 53
> Domain Name Server is 10 .0 .2 .3
> Ignoring BOOTP/DHCP option code 51
> Hostname is foo.bar
> Boot file is /rtems.exe
> Subnet mask is 255 .255 .255 .0
> Server ip address is 10 .0 .2 .2
> Gateway ip address is 10 .0 .2 .2
> Log server ip address is 10 .0 .2 .2
> Trying symfile 'BUILTIN', system script 'st.sys'
> Type 'cexpsh.help()' for help (no quotes)
> 'st.sys':
> ne2000: device timeout
> opening script file: I/O error
> Cexp>cexpMod
> cexpModIterate()                cexpModuleInitOnce()
> cexpModuleDumpGdbSectionInfo()  cexpModuleLoad()
> cexpModuleFindByName()          cexpModuleName()
> cexpModuleFree()                cexpModuleUnload()
> cexpModuleInfo()
> Cexp>cexpModuleInfo()
> Module 'SYSTEM-BUILTIN' (0x008bcb94):
>    Text starts at: 0xdeadbeef
> 0x00000000 (0)
> Cexp>
> Need a little help here...
> -- dc
> On 10-Feb-09, at 12:43 PM, Joel Sherrill wrote:
>> I am happy to report that the if_fxp (Intel i8255x driver)
>> works with QEMU with any of the following NIC models
>> specified:
>> i82551
>> i82557b
>> i82559er
>> That is in addition to the ne2k_isa we historically used.
>> That leaves pcnet, ne2k_pci,  pcnet, and rtl8139 as the
>> remaining NICs simulated for i386 qemu that we
>> don't support.
>> --joel
>>>>> Daron Chabot wrote:
>>>>>> On 10-Feb-09, at 7:02 AM, PowerMan wrote:
>>>>>>> I do it as the follow steps:
>>>>>>> 1. download QEMU from  http://bellard.org/qemu/qemu-0.9.1-
>>>>>>> i386.tar.gz
>>>>>>> 2. install it
>>>>>>>     tar xfz qemu-0.9.1-i386.tar.gz -C /
>>>>>>> 3. download rtems floppy image from ftp server :
>>>>>>>     ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-boot.img
>>>>>>> 4. download ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-
>>>>>>> grub.cfg
>>>>>>>     and copy it to my root directory /
>>>>>>> 5. mkdir /capture
>>>>>>>    cp hello.exe /capture/capture.exe
>>>>>>> 6. run qemu
>>>>>>>     qemu -fda rtems-boot.img -boot a -hda /dev/sda
>>>>>>> but the capture.exe (which is actually helloworld I build
>>>>>>> with  rtems-4.7.3) does not run as I excepted.
>>>>>>> This capture.exe could run on my host by modifying /boot/grub/
>>>>>>> menu.lst
>>>>>>> I type the following commands in grub:
>>>>>>> grub> set root=(hd0,0)
>>>>>>> grub> set kernel=/capture/capture.exe
>>>>>>> grub> boot
>>>>>>> then grub told me:
>>>>>>> error: no loaded kernel
>>>>>>> grub> multiboot /capture/capture.exe
>>>>>>> then grub told me:
>>>>>>> error: Couldn't open file
>>>>>>> Could somebody help me?
>>>>>>> My host is openSUSE 11.1, my disk information is:
>>>>>>> /dev/sda1              3091312    516528   2417752  18% /
>>>>>>> udev                    252876      5428    247448   3% /dev
>>>>>>> /dev/sda8              3605268    153972   3268160   5% /home
>>>>>>> /dev/sda7              1130540    221192    851920  21% /tmp
>>>>>>> /dev/sda9              6412052   3541120   2545216  59% /usr
>>>>>>> /dev/sda6              1130540    193556    879556  19% /var
>>>>>>> grub> ls
>>>>>>> then grub told me:
>>>>>>> (fd0) (hd0) (hd0,0) (hd0,4) (hd0,5) (hd0,6) (hd0,7) (hd0,8)
>>>>>>> they didn't match my host disk partition number
>>>>>> Grub is not a requirement for using Qemu, and may actually
>>>>>> complicate  the matter.
>>>>>> I've had success with variations on the following command:
>>>>>>     qemu -no-reboot -m 128 -boot n -tftp /path/to/exe/parent/
>>>>>> directory - bootp /yourRtemsApp.exe -serial stdio
>>>>> I can make this work for hello and ticker but not for networked
>>>>> applications.  Do you have a way to run networked applications
>>>>> this way?
>>>> Nope. Sorry. I haven't found the magic qemu-cmdline/network-
>>>> config combo yet. It has been awhile since I was playing around
>>>> with Qemu and networked RTEMS apps, but I recall that one of the
>>>> problems for me was that mac os x has no concept of tun/tap
>>>> interfaces (at least not natively; there is a third-party driver,
>>>> but I had no luck with it).
>>>> I'll revisit things tonight and see if I figure anything out.
>>> I can run networked applications just not after using tftp/bootp.
>>> I have to boot them from a floppy.
>>> I am curious if the Intel FXP driver works on qemu.  :)
>>>>> I am trying to have some demos for a GSoC/RTEMS presentation
>>>>> on Monday at University of Tennessee at Chattanooga and was
>>>>> actually trying this out today. :)
>>>>> --joel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>   Support Available             (256) 722-9985
