i386 now has shared IRQ support
Fri Feb 20 20:19:44 UTC 2009
Daron Chabot wrote:
> On Thu, Feb 19, 2009 at 2:23 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi,
>> I just committed the modifications required
>> to support shared IRQs on the i386.  This should
>> put the PowerPC and x86 IRQ processing at
>> feature parity.
>> It now looks like there is an opportunity to
>> eliminate some of the shared code across the
>> two ports irq.c files.
> I can confirm that IRQ sharing works with the test-bench below:
> pc386 BSP (RTEMS cvs HEAD):
> - 3 GHz P4 with 4 PCI-VME cards (3 of which share IRQ 11, 4th on IRQ
> 9) + one PCI NIC (on IRQ 5), an ADMtek Centaur
> (libchip/network/if_dc.c).
Nice.  Did it help you clean up your code any?
> Thanks, Joel!
Thank you for testing it.
> -- dc
