i386 now has shared IRQ support
Daron Chabot daron.chabot at gmail.com
Fri Feb 20 20:30:00 UTC 2009
On Fri, Feb 20, 2009 at 2:19 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Daron Chabot wrote:
>> On Thu, Feb 19, 2009 at 2:23 PM, Joel Sherrill
>>> Hi,
>>> I just committed the modifications required
>>> to support shared IRQs on the i386.  This should
>>> put the PowerPC and x86 IRQ processing at
>>> feature parity.
>>> It now looks like there is an opportunity to
>>> eliminate some of the shared code across the
>>> two ports irq.c files.
>> I can confirm that IRQ sharing works with the test-bench below:
>> pc386 BSP (RTEMS cvs HEAD):
>> - 3 GHz P4 with 4 PCI-VME cards (3 of which share IRQ 11, 4th on IRQ
>> 9) + one PCI NIC (on IRQ 5), an ADMtek Centaur
>> (libchip/network/if_dc.c).
> Nice.  Did it help you clean up your code any?
Cleaned things up a little (30-40 lines), as I could do away with some
test logic, building the list of shared handlers, looping over list in
the ISR, etc. I would much rather have that capability in the
rtems-core than in my application code...
>> Thanks, Joel!
> Thank you for testing it.
More than happy to:  I have absolutely no objections to throwing away
cludge-code !
>> -- dc
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>  Support Available             (256) 722-9985
