i386 now has shared IRQ support
Fri Feb 20 20:36:49 UTC 2009
Daron Chabot wrote:
> On Fri, Feb 20, 2009 at 2:19 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Daron Chabot wrote:
>>> On Thu, Feb 19, 2009 at 2:23 PM, Joel Sherrill
>>>> Hi,
>>>> I just committed the modifications required
>>>> to support shared IRQs on the i386.  This should
>>>> put the PowerPC and x86 IRQ processing at
>>>> feature parity.
>>>> It now looks like there is an opportunity to
>>>> eliminate some of the shared code across the
>>>> two ports irq.c files.
>>> I can confirm that IRQ sharing works with the test-bench below:
>>> pc386 BSP (RTEMS cvs HEAD):
>>> - 3 GHz P4 with 4 PCI-VME cards (3 of which share IRQ 11, 4th on IRQ
>>> 9) + one PCI NIC (on IRQ 5), an ADMtek Centaur
>>> (libchip/network/if_dc.c).
>> Nice.  Did it help you clean up your code any?
> Cleaned things up a little (30-40 lines), as I could do away with some
> test logic, building the list of shared handlers, looping over list in
> the ISR, etc. I would much rather have that capability in the
> rtems-core than in my application code...
>>> Thanks, Joel!
>> Thank you for testing it.
> More than happy to:  I have absolutely no objections to throwing away
> cludge-code !
Now we need to follow that up by figuring out how to merge and
shared the libbsp/powerpc/shared/irq and libbsp/i386/shared/irq
irq.c files. :-D
--joel
