Weird problem on rs232 vs USB-serial...
mike antispam21 at verizon.net
Mon Feb 23 19:02:38 UTC 2009
Hi all,
We have a Leon2-based board using the RTEMS leon2 BSP. The host is x86
running CentOS 2.6.
With a simple application that outputs to /dev/console for stdio (printf):
- with the board connected directly to COM1 of the host, no output is seen
- with the board connected to a USB<->serial adapter (Keyspan), outputs
and inputs were fine
* This is with the same app initializing the UART to 38400, 8N1, no flow
control.
* On the host, we just use 'minicom' set for 38400, 8N1, no flow control
    (/dev/ttyS1 in the 1st case and /dev/ttyUSB0 in the 2nd case)
What could possibly be the cause?
Thanks for any comments/pointers.
 -mike-
