Weird problem on rs232 vs USB-serial...
Tue Feb 24 00:17:58 UTC 2009
mike wrote:
> Joel Sherrill wrote:
>>> One more addition is:
>>> - if I use 'grmon' to connect to the DSU port, then load the same app
>>> with grmon and run,
>>> I can see outputs coming out of the COM1 port.
>>> - it was when I used the onboard bootrom to load the app to ram, then
>>> jump to it that I didn't
>>> see any outputs on COM1 port. Again, when it's connected to
>>> USB<->serial, the outputs
>>> came out fine, with the same app.
>> Could the flow control settings be wrong in the comm application when
>> using the ttys0?
>> I recall that minicom on unix defaults to HW flow control on.
> Thanks Joel, I did set the minicom to use 'no flow control'...
> It seems that the only variable is "ttyS1" vs "ttyUSB0" but I don't know
> what else to look...
Check /proc/interrupts to see if the kernel is getting interrupts from the
UART for ttyS1. I would not bother with USB interrupts as this is a shared bus
and the interrupt count to USB serial I/O does not match easily.
I would also connect just a cable to the port and connect together the TX/RX
pins then type something on Minicom. You should see the interrupt count go up
by 2 for each character pressed. This will help you isolate the host from
cable from target.
Regards
