ANN: lm32-rtems4.10 toolchain rpms
Wed Feb 25 15:51:38 UTC 2009
Jon Beniston wrote:
> Hi Joel,
> Looking at the hardware configuration on this page used for the port:
> http://www.mrf.fi/index.php?option=com_content&task=view&id=60&Itemid=63, it
> seems you will need to pass the simulator some options to get the memory and
> peripherals in the right place. Also, please note that some of the
> peripherals might not be supported or may differ from what is in the h/w.
> lm32-elf-run --help will show options that can be passed to the simulator.
> E.g. something like this will add a UART:
> --hw-device lm32cpu --hw-device "lm32uart/reg 0x80006000 0x100" --hw-device
> "/lm32uart > int int1 /lm32cpu"
I don't think it is getting that far. :(
08000000 A RamBase
08000000 T _init
I can't even set a breakpoint at _init.  So I think the
RAM addresses must not be right.    And it looks from
the link you passed that they also used a timer and
ethernet.
Hopefully Jukka will pipe up shortly.
Thanks.
--joel
> Regards,
> Jon
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 25 February 2009 14:38
> To: Jon Beniston
> Cc: 'Ralf Corsepius'; 'RTEMS Users'; Jukka Pietarinen
> Subject: Re: ANN: lm32-rtems4.10 toolchain rpms
> Jon Beniston wrote:
>> Hi,
>>> When I do a "tar sim; load; run",
>> This should work.
>>> core: 4 byte read to unmapped address 0x800001c at 0x800001c
>> What link script are you using? How much memory does it expect and where?
>> What peripherals is it expecting?
> I am using the lm32_evr BSP in RTEMS CVS.  I am cc'ing Jukka since he wrote
> the BSP.
>> Cheers,
>> Jon
