Documentation question - Interrupt Manager
Fri Feb 27 14:32:23 UTC 2009
Manuel wrote:
> Hi all,
> Have a documentation question regarding the RTEMS directives that can
> be used inside an ISR.
> Can’t these directives be also called from an ISR:
>   rtems_interrupt_enable
>   rtems_interrupt_disable
>   rtems_interrupt_flash
>   rtems_interrupt_is_in_progress
All of these for sure.  RTEMS uses the underlying SuperCore ISR
routines they wrap. :)
>   rtems_interrupt_catch
This should be save as well.  But why would you want to?
> We believe that they can (perhaps not the catch), but not sure. The
> rtems_interrupt_is_in_progress makes all the sense being used inside
> an ISR.
Definitely.  That was its intent.
> If these functions can be used, would it be possible to update the
> documentation?
Sure.
> Looking forward to ear your feedback.
> Kind Regards
> Manuel Coutinho
