Watchdog interrupt
Manuel
manuel.coutinho at edisoft.pt
Fri Feb 27 16:36:28 UTC 2009
Hi all,
Have a question regarding the watchdog interrupt. I think that typically,
the watchdog interrupt should be a non-maskable interrupt, so that the
interrupts should be serviced regularly and not be dependent on the
interrupt latency.
If the watchdog interrupt is maskable and if a problem occurs and the
interrupts are left disabled for a long period of time, the watchdog
interrupt will never be triggered and the system might not have a chance to
detect that.
The other solution would be never to disable the watchdog interrupt.
Of course, if the watchdog interrupt is non-maskable or if it never
disabled, then it must not call any RTEMS directive.
What is your opinion about this subject.
Kind regards
Manuel Coutinho
URL: <http://lists.rtems.org/pipermail/users/attachments/20090227/20930ef1/attachment.html>
