Documentation question - Interrupt Manager
Manuel manuel.coutinho at edisoft.pt
Fri Feb 27 16:36:59 UTC 2009
Thank you for solving this issue so fast! :)
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Friday, February 27, 2009 2:32 PM
> To: Manuel
> Cc: rtems-users at rtems.com
> Subject: Re: Documentation question - Interrupt Manager
> Manuel wrote:
> > Hi all,
> > Have a documentation question regarding the RTEMS directives that can
> > be used inside an ISR.
> > Can't these directives be also called from an ISR:
> >   rtems_interrupt_enable
> >   rtems_interrupt_disable
> >   rtems_interrupt_flash
> >   rtems_interrupt_is_in_progress
> All of these for sure.  RTEMS uses the underlying SuperCore ISR
> routines they wrap. :)
> >   rtems_interrupt_catch
> This should be save as well.  But why would you want to?
> > We believe that they can (perhaps not the catch), but not sure. The
> > rtems_interrupt_is_in_progress makes all the sense being used inside
> > an ISR.
> Definitely.  That was its intent.
> > If these functions can be used, would it be possible to update the
> > documentation?
> Sure.
> > Looking forward to ear your feedback.
> > Kind Regards
> > Manuel Coutinho
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>    Support Available             (256) 722-9985
