help: failed to use qemu
Daron Chabot
daronchabot at gmail.com
Tue Feb 10 13:59:41 UTC 2009
On 10-Feb-09, at 7:02 AM, PowerMan wrote:
> I do it as the follow steps:
> 1. download QEMU from http://bellard.org/qemu/qemu-0.9.1-i386.tar.gz
> 2. install it
> tar xfz qemu-0.9.1-i386.tar.gz -C /
> 3. download rtems floppy image from ftp server :
> ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-boot.img
> 4. download ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-grub.cfg
> and copy it to my root directory /
> 5. mkdir /capture
> cp hello.exe /capture/capture.exe
> 6. run qemu
> qemu -fda rtems-boot.img -boot a -hda /dev/sda
> but the capture.exe (which is actually helloworld I build with
> rtems-4.7.3) does not run as I excepted.
> This capture.exe could run on my host by modifying /boot/grub/menu.lst
> I type the following commands in grub:
> grub> set root=(hd0,0)
> grub> set kernel=/capture/capture.exe
> grub> boot
> then grub told me:
> error: no loaded kernel
> grub> multiboot /capture/capture.exe
> then grub told me:
> error: Couldn't open file
> Could somebody help me?
> My host is openSUSE 11.1, my disk information is:
> /dev/sda1 3091312 516528 2417752 18% /
> udev 252876 5428 247448 3% /dev
> /dev/sda8 3605268 153972 3268160 5% /home
> /dev/sda7 1130540 221192 851920 21% /tmp
> /dev/sda9 6412052 3541120 2545216 59% /usr
> /dev/sda6 1130540 193556 879556 19% /var
> grub> ls
> then grub told me:
> (fd0) (hd0) (hd0,0) (hd0,4) (hd0,5) (hd0,6) (hd0,7) (hd0,8)
> they didn't match my host disk partition number
Grub is not a requirement for using Qemu, and may actually complicate
the matter.
I've had success with variations on the following command:
qemu -no-reboot -m 128 -boot n -tftp /path/to/exe/parent/directory -
bootp /yourRtemsApp.exe -serial stdio
-- dc
