help: failed to use qemu
Daron Chabot
daronchabot at gmail.com
Tue Feb 10 18:07:24 UTC 2009
Joel Sherrill wrote:
> Daron Chabot wrote:
>> On 10-Feb-09, at 7:02 AM, PowerMan wrote:
>>> I do it as the follow steps:
>>> 1. download QEMU from http://bellard.org/qemu/qemu-0.9.1-i386.tar.gz
>>> 2. install it
>>> tar xfz qemu-0.9.1-i386.tar.gz -C /
>>> 3. download rtems floppy image from ftp server :
>>> ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-boot.img
>>> 4. download ftp://ftp.rtems.com/pub/rtems/qemu/i386-pc/rtems-grub.cfg
>>> and copy it to my root directory /
>>> 5. mkdir /capture
>>> cp hello.exe /capture/capture.exe
>>> 6. run qemu
>>> qemu -fda rtems-boot.img -boot a -hda /dev/sda
>>> but the capture.exe (which is actually helloworld I build with
>>> rtems-4.7.3) does not run as I excepted.
>>> This capture.exe could run on my host by modifying /boot/grub/menu.lst
>>> I type the following commands in grub:
>>> grub> set root=(hd0,0)
>>> grub> set kernel=/capture/capture.exe
>>> grub> boot
>>> then grub told me:
>>> error: no loaded kernel
>>> grub> multiboot /capture/capture.exe
>>> then grub told me:
>>> error: Couldn't open file
>>> Could somebody help me?
>>> My host is openSUSE 11.1, my disk information is:
>>> /dev/sda1 3091312 516528 2417752 18% /
>>> udev 252876 5428 247448 3% /dev
>>> /dev/sda8 3605268 153972 3268160 5% /home
>>> /dev/sda7 1130540 221192 851920 21% /tmp
>>> /dev/sda9 6412052 3541120 2545216 59% /usr
>>> /dev/sda6 1130540 193556 879556 19% /var
>>> grub> ls
>>> then grub told me:
>>> (fd0) (hd0) (hd0,0) (hd0,4) (hd0,5) (hd0,6) (hd0,7) (hd0,8)
>>> they didn't match my host disk partition number
>> Grub is not a requirement for using Qemu, and may actually
>> complicate the matter.
>> I've had success with variations on the following command:
>> qemu -no-reboot -m 128 -boot n -tftp
>> /path/to/exe/parent/directory - bootp /yourRtemsApp.exe -serial stdio
> I can make this work for hello and ticker but not for networked
> applications. Do you have a way to run networked applications
> this way?
Nope. Sorry. I haven't found the magic qemu-cmdline/network-config combo
yet. It has been awhile since I was playing around with Qemu and
networked RTEMS apps, but I recall that one of the problems for me was
that mac os x has no concept of tun/tap interfaces (at least not
natively; there is a third-party driver, but I had no luck with it).
I'll revisit things tonight and see if I figure anything out.
> I am trying to have some demos for a GSoC/RTEMS presentation
> on Monday at University of Tennessee at Chattanooga and was
> actually trying this out today. :)
> --joel
