Unable to initialize system clock
João Craveiro
jcraveiro at lasige.di.fc.ul.pt
Thu Feb 12 15:40:09 UTC 2009
The Makefiles (particularly the one from hello_world_cPMK) have some
peculiarities, like prefixing, and linking together with the object
generated from hello_world_cP1. This is a requisite of the system we're
designing. Meanwhile, I experimented transferring manuelTesteP1() to the
PMK source (as P1manuelTesteP1()) and generating the executable only
from that code, and it worked, so I guess the problem lies in the build
process.
Thank you,
JC
Q: Why is this email 5 sentences or less?
A: http://five.sentenc.es
Joel Sherrill wrote:
> João Craveiro wrote:
>> Hello there,
>> I'm currently trying to get a little demonstrator application, not
>> developed by me and that (supposedly) ran on RTEMS 4.6.2, to run on
>> RTEMS 4.8. I already hunted the bugs that didn't allow successful
>> compilation, but I can't get past this after booting:
>> «Initialized console on port CONSOLE
>> Unable to initialize system clock»
>> Sometimes --i.e., in some builds-- the second message is replaced by
>> some weird characters. I'm using the pc386 bsp, and this happens both
>> with QEMU and effectively booting from a floppy disk.
>> Anybody has any clues?
> Is the application small enough to post? This doesn't sound
> familiar at all and this isn't enough to debug from.
>> Thank you in advance,
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090212/e507ea99/attachment-0001.zip>
Type: text/x-vcard
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090212/e507ea99/attachment-0001.vcf>
