rtems_bsdnet_fdToSocket()
Chris Johns
chrisj at rtems.org
Thu Feb 12 21:58:31 UTC 2009
Till Straumann wrote:
> IMHO rtems_bsdnet_fdToSocket() doesn't
> verify thoroughly enough that the file
> descriptor passed in is really a socket.
> If you e.g., try getsockname() on a fd
> that was opened on a termios device then
> a crash may result.
> I propose to let rtems_bsdnet_fdToSocket()
> test not only that iop->data1 is NULL but
> to add an additional test.
> Either
> 1) add a new flag LIBIO_FLAGS_ISSOCK
> which is set by rtems_bsdnet_makeFdForSocket()
> and tested by rtems_bsdnet_fdToSocket()
> 1a) instead of one flag we could use a few
> more bits and create a LIBIO_FLAGS_IOP_TYPE
> bitmask (in case the need for other special
> cases besides sockets arises in the future).
> The test would then look like
> if ( LIBIO_FLAGS_IOP_TYPE(iop->flags) != LIBIO_FLAGS_IOP_TYPE_SOCK ) {
> errno = ENOTSOCK;
> return NULL;
> Sidenote: IMO, if data1 == NULL then errno should
> also be ENOTSOCK instead of EBADF.
The LIBIO flags do not describe the fd rather they deal with what you can do.
I do not like the type of fd being added to the flags.
NetBSD has a type field in the fp referenced by the fd:
int
getsock(struct filedesc *fdp, int fdes, struct file **fpp)
struct file *fp;
if ((fp = fd_getfile(fdp, fdes)) == NULL)
return (EBADF);
FILE_USE(fp);
if (fp->f_type != DTYPE_SOCKET) {
FILE_UNUSE(fp, NULL);
return (ENOTSOCK);
*fpp = fp;
return (0);
I would prefer this.
Regards
> 2) alternatively, rtems_bsdnet_fdToSocket() could
> test if iop->handlers == socket_handlers.
> socket_handlers would then have to become a globally
> visible symbol (right now a static variable).
> Unfortunately, this would introduce some asymmetry
> (fdToSocket() refers to global symbol, makeFdForSocket
> gets pointer to handlers passed in).
> If nobody objects or has a better idea then I would
> implement 1a), create a PR and commit to 4.9 and HEAD.
> RFC
> -Till
> rtems-users mailing list
> rtems-users at rtems.com
