rtems_bsdnet_fdToSocket()
Thu Feb 12 22:26:09 UTC 2009
Till Straumann wrote:
>>> IMHO rtems_bsdnet_fdToSocket() doesn't
>>> verify thoroughly enough that the file
>>> descriptor passed in is really a socket.
>>> If you e.g., try getsockname() on a fd
>>> that was opened on a termios device then
>>> a crash may result.
>>> I propose to let rtems_bsdnet_fdToSocket()
>>> test not only that iop->data1 is NULL but
>>> to add an additional test.
>>> Either
>>> 1) add a new flag LIBIO_FLAGS_ISSOCK
>>>    which is set by rtems_bsdnet_makeFdForSocket()
>>>    and tested by rtems_bsdnet_fdToSocket()
>>> 1a) instead of one flag we could use a few
>>>    more bits and create a LIBIO_FLAGS_IOP_TYPE
>>>    bitmask (in case the need for other special
>>>    cases besides sockets arises in the future).
>>>    The test would then look like
>>>    if ( LIBIO_FLAGS_IOP_TYPE(iop->flags) != LIBIO_FLAGS_IOP_TYPE_SOCK
>>>        errno = ENOTSOCK;
>>>        return NULL;
>>>    Sidenote: IMO, if data1 == NULL then errno should
>>>              also be ENOTSOCK instead of EBADF.
>> The LIBIO flags do not describe the fd rather they deal with what you
>> can do. I do not like the type of fd being added to the flags.
>> NetBSD has a type field in the fp referenced by the fd:
> Problemo being that libio has no such thing. It has
> absolutely no knowledge about what is attached to
> 'data', 'data1', 'file-info'.
> Where do you see an equivalent to fp_type in the iop
> or how would you propose that, given a iop, the
> code can figure out what kind of object
> is attached to e.g., 'data1' ?
> Do you like testing the 'handlers' better?
Looking at libcsupport/src/libio_socket.c, that's the only
thing you can currently rely on.
Might not be a bad generic check.  Worth a libio macro
like rtems_libio_handlers_match?
--joel
> T.
>> int
>> getsock(struct filedesc *fdp, int fdes, struct file **fpp)
>>         struct file     *fp;
>>         if ((fp = fd_getfile(fdp, fdes)) == NULL)
>>                 return (EBADF);
>>         FILE_USE(fp);
>>         if (fp->f_type != DTYPE_SOCKET) {
>>                 FILE_UNUSE(fp, NULL);
>>                 return (ENOTSOCK);
>>         *fpp = fp;
>>         return (0);
>> I would prefer this.
>> Regards
>> Chris
>>> 2) alternatively, rtems_bsdnet_fdToSocket() could
>>>    test if iop->handlers == socket_handlers.
>>>    socket_handlers would then have to become a globally
>>>    visible symbol (right now a static variable).
>>>    Unfortunately, this would introduce some asymmetry
>>>    (fdToSocket() refers to global symbol, makeFdForSocket
>>>    gets pointer to handlers passed in).
>>> If nobody objects or has a better idea then I would
>>> implement 1a), create a PR and commit to 4.9 and HEAD.
>>> RFC
>>> -Till
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
