thread-safety of rtems_cpu_usage_report
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 13 20:40:12 UTC 2009
Till Straumann wrote:
>>> I look at rtems_cpu_usage_report() and it
>>> seems to me that the code merrily scans
>>> the _Objects_Information_table and accesses
>>> the Thread_Control blocks it finds there
>>> w/o using any kind of protection.
>>> What happens, e.g., if the _Objects_Information_table
>>> gets extended or otherwise modified by another
>>> thread while the code is scanning the table?
>>> Am I missing something?
>> no. :(
>> I had always wanted to change it to a loop
>> from min to max id around a "get cpu use"
>> task id based information call. Then it
>> can fail on each one.
>> But anything using iterate over all tasks is
>> not thread safe. Perhaps it would be best
>> to put that call in an allocation critical section.
>> Then the set cannot change since there are
>> no create/delete's allowed.
> Definitely deserves some thought.
> E.g., 'sync' looks quite a bit scary...
I think using the allocation mutex would
prevent any issues here also. You wouldn't be
able to malloc memory or create threads.
> T.
>>> -- Till
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mail
