patches for newlib-1.16.0 and newlib-1.15.0
Kate Feng feng1 at bnl.gov
Mon Feb 23 20:12:32 UTC 2009
Hi,
The patches appear confused due to the option flag '-D' that it deserves
to be explained further :
In newlib-1.16.0/newlib/configuire.host or
newlib-1.15.0/newlib/configuire.host:
for the case of  '*-*-rtems*)' (e.g. line #529) , one can add the
-DHAVE_BLKSIZE
option to  the 'newlib_cflags' (e.g. line #532) to improve the
performance the
RTEMS-NFS.
Cheers,
Kate
Kate Feng wrote:
> Hi,
> The attach are the patches I used for newlib-1.15.0 ( RTEMS 4.8.0)
> and newlib-1.16.0 (RTEMS 4.9.1) to increase the performance of
> the NFS by over a factor of ten.    Was a similar patch applied
> to the pre-built binary for rtems-4.9 and rtems-4.8 development tools ?
> If not, then the performance of NFS would act sluggishly.
> Regards,
> Kate
> --- newlib-1.16.0/newlib/configure.host.orig	2009-02-20 15:26:27.000000000 -0500
> +++ newlib-1.16.0/newlib/configure.host	2009-02-20 15:36:33.000000000 -0500
> @@ -529,7 +529,7 @@
>    *-*-rtems*)
>  	default_newlib_io_long_long="yes"
>  	default_newlib_io_c99_formats="yes"
> -	newlib_cflags="${newlib_cflags} -DMALLOC_PROVIDED -DEXIT_PROVIDED -DMISSING_SYSCALL_NAMES -DSIGNAL_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_OPENDIR -DNO_EXEC -DHAVE_FCNTL"
> +	newlib_cflags="${newlib_cflags} -DMALLOC_PROVIDED -DEXIT_PROVIDED -DMISSING_SYSCALL_NAMES -DSIGNAL_PROVIDED -DREENTRANT_SYSCALLS_PROVIDED -DHAVE_OPENDIR -DNO_EXEC -DHAVE_BLKSIZE -DHAVE_FCNTL"
>  # VxWorks supplies its own version of malloc, and the newlib one
>  # doesn't work because VxWorks does not have sbrk.
> --- newlib-1.15.0/newlib/configure.host.orig	2006-12-18 16:49:14.000000000 -0500
> +++ newlib-1.15.0/newlib/configure.host	2008-04-01 14:09:24.000000000 -0400
> @@ -510,7 +510,7 @@
>  #  NOTE: When newlib malloc uses a semaphore, RTEMS will switch to that.
>    *-*-rtems*)
> rtems-users mailing list
> rtems-users at rtems.com
