回复: BSP for Atmel AT91RM9200-EK
xu ray
rayx.cn at gmail.com
Wed Feb 25 13:26:20 UTC 2009
2009/2/25, Dhanesh S. <dhanesh.s at nestgroup.net>:
> Hi All,
> I am a beginner in RTEMS and trying to port this on Atmel Evaluation Kit
> 'AT91RM9200-EK'.
> Has anyone got the exact BSP for AT91RM9200-EK ?
> I could find the BSP for cogent board CSB337. Would this be easy to
> modify it to support my board?
It is very easy to port csb337 BSP to AT91RM9200-EK. Maybe just a few
changes in registers related to frequency and memory map.
> Regards,
> Dhanesh
> ***** Confidentiality Statement/Disclaimer *****
> This message and any attachments is intended for the sole use of the
> intended recipient. It may contain confidential information. Any
> unauthorized use, dissemination or modification is strictly prohibited. If
> you are not the intended recipient, please notify the sender immediately
> then delete it from all your systems, and do not copy, use or print.
> Internet communications are not secure and it is the responsibility of the
> recipient to make sure that it is virus/malicious code exempt.
> The company/sender cannot be responsible for any unauthorized alterations or
> modifications made to the contents. If you require any form of confirmation
> of the contents, please contact the company/sender. The company/sender is
> not liable for any errors or omissions in the content of this message.
Thanks & Best Regards!
Ray, Xu
