Documentation question - Interrupt Manager
Fri Feb 27 16:43:56 UTC 2009
Manuel wrote:
> Thank you for solving this issue so fast! :)
This one was easy. They are not all so easy. LOL!
--joel
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: Friday, February 27, 2009 2:32 PM
>> To: Manuel
>> Cc: rtems-users at rtems.com
>> Subject: Re: Documentation question - Interrupt Manager
>> Manuel wrote:
>>> Hi all,
>>> Have a documentation question regarding the RTEMS directives that can
>>> be used inside an ISR.
>>> Can't these directives be also called from an ISR:
>>>   rtems_interrupt_enable
>>>   rtems_interrupt_disable
>>>   rtems_interrupt_flash
>>>   rtems_interrupt_is_in_progress
>> All of these for sure.  RTEMS uses the underlying SuperCore ISR
>> routines they wrap. :)
>>>   rtems_interrupt_catch
>> This should be save as well.  But why would you want to?
>>> We believe that they can (perhaps not the catch), but not sure. The
>>> rtems_interrupt_is_in_progress makes all the sense being used inside
>>> an ISR.
>> Definitely.  That was its intent.
>>> If these functions can be used, would it be possible to update the
>>> documentation?
>> Sure.
>>> Looking forward to ear your feedback.
>>> Kind Regards
>>> Manuel Coutinho
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
