MVME2700 stable
Wed Jan 7 18:39:25 UTC 2009
Matt Rippa wrote:
> Hi all -
> I'd like to report a new bsp is working and running EPICS. I've
> attached the patches needed. I did remove what appears to be a
> bug in motorola.c. On line 343 the following code always returned
> the first board entry. Removing this allowed all entries to be
> queried.
>      if (mot_boards[entry].base_type == 0) {
>        mot_entry = entry;
>        break;
> So, would I need to include anything else to formally commit this
> bsp?
I assume you are using 4.9.x.  If this is the case, then...
Given that this isn't a major addition, I would prefer it
have a PR (http://www.rtems.org/bugzilla) so it can be
applied to the 4.9 branch.
Did you add a file named make/custom/mvme2700.cfg?
It wasn't attached.
If we are just adding it to the CVS head, then this is
enough.
Adding entries to the appropriate Wiki pages would
be greatly appreciated.  Start here
http://www.rtems.org/wiki/index.php/BoardSupportPackageInformation#PowerPC_BSPs
> Thanks to Till Straumann and Eric Norum for getting me off the
> ground with RTEMS! :)
Ditto!  Till.. please comment publicly on this.  I would like your
blessing before applying.
Thanks.
> -Matt Rippa
> Gemini Observatory
