MVME2700 stable
Matt Rippa mrippa at gemini.edu
Wed Jan 7 20:28:19 UTC 2009
Yes this has been tested on 4.9.1. I used the mvme2307.cfg and
just copied it to mvme2700.cfg.
I'll fill in the appropriate PR. As for the wiki I noticed an
entry for a 2600 (which is the same board AFAIK), and reports a
failed "netdemo". Perhaps I should merge my notes into the 2600
page and change the tile to "2600/2700"???
However, what's the affect of configuring abstract bsp's in the
way you describe? I'm assuming I'd still be able to run configure
with --enable-rtemsbsp="mvme2700". Anything else would be
confusing I think.
Thanks,
-Matt
Till Straumann wrote:
> I had a quick glance at the patches and I would also
> think that they are minor and can/should be added to
> the 4.9 branch.
> However, I'd prefer to not make this a 'special' BSP
> (i.e., no change to 'configure', no extra mvme2700.cfg).
> The normal mvme2304 BSP should work fine, all the
> differences are detected and handled at run-time.
> -- Till
> Joel Sherrill wrote:
>> Matt Rippa wrote:
>>> Hi all -
>>> I'd like to report a new bsp is working and running EPICS. I've
>>> attached the patches needed. I did remove what appears to be a
>>> bug in motorola.c. On line 343 the following code always returned
>>> the first board entry. Removing this allowed all entries to be
>>> queried.
>>>      if (mot_boards[entry].base_type == 0) {
>>>        mot_entry = entry;
>>>        break;
>>> So, would I need to include anything else to formally commit this
>>> bsp?
>> I assume you are using 4.9.x.  If this is the case, then...
>> Given that this isn't a major addition, I would prefer it
>> have a PR (http://www.rtems.org/bugzilla) so it can be
>> applied to the 4.9 branch.
>> Did you add a file named make/custom/mvme2700.cfg?
>> It wasn't attached.
>> If we are just adding it to the CVS head, then this is
>> enough.
>> Adding entries to the appropriate Wiki pages would
>> be greatly appreciated.  Start here
>> http://www.rtems.org/wiki/index.php/BoardSupportPackageInformation#PowerPC_BSPs
>>> Thanks to Till Straumann and Eric Norum for getting me off the
>>> ground with RTEMS! :)
>> Ditto!  Till.. please comment publicly on this.  I would like your
>> blessing before applying.
>> Thanks.
>>> -Matt Rippa
>>> Gemini Observatory
