Rtems for a space project
Massimo Tipaldi
mtipaldi at cgspace.it
Mon Jan 12 08:45:20 UTC 2009
Dear all,
I work for an aerospace company and my activity on RTEMS is aimed at
evaluating its usage for the on-board SW of an European Space Agency
satellite.
Rtems has been already used in the some ESA mission (i.e. Herschel/Planck).
In any case, it would have been nice to use RTEMS with a Windows host,
but it seems so far that it is not possible. Executable files compiled
on a Windows host are not compatible with the elf/multiboot
specifications (surely for what we have seen in the last weeks).
Moreover, it would be even nice to me
1) to write down this issue and to try to solve it in the next RTEMS
versions or,
2) if it is somehow already possible, to show the steps to generate a
RTEMS application on a Windows host in an ELF format.
Should the Rtems community solve this issue, I'd be very grateful.
Massimo
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute in questo messaggio di posta elettronica
e relativi allegati sono riservate e confidenziali e ne e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system. Please do not copy it or use it for any
purposes, or disclose its contents to any other person: to do so could
be a breach of confidence. Thank you for your co-operation. Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
