Rtems for a space project
Massimo Tipaldi mtipaldi at cgspace.it
Mon Jan 12 10:05:13 UTC 2009
Dear Ralf,
for all the steps that I have perfomed, see my e-mails on rtems-users
(find Massimo Tipaldi);
In particular, take a look at:
1) RTEMS/QEMU/GRUB on Windows (07 Jan 2009 11:03:52 +0100)
2) RTEMS/QEMU/GRUB on Windows (08 Jan 2009 16:49:58 +0100)
For the modifications on Makefile.inc, see
1) QEMU/GRUB: No multiboot header found (22 Dec 2008 16:22:28 +0100)
(the only difference is that RTEMS is now installed in
d:\opt\src\rtems\i386\)
Massimo
Ralf Corsepius ha scritto:
> Massimo Tipaldi schrieb:
>> Dear all,
>> I work for an aerospace company and my activity on RTEMS is aimed at
>> evaluating its usage for the  on-board SW of an European Space Agency
>> satellite.
>> Rtems has been already used in the some ESA mission (i.e.
>> Herschel/Planck).
>> In any case, it would have been nice to use RTEMS with a Windows host,
>> but it seems so far that it is not possible. Executable files compiled
>> on a Windows host are not compatible with the elf/multiboot
>> specifications (surely for what we have seen in the last weeks).
> Pardon, but this all is way too vague to be able to comment on. Which I
> issues do you have?
>> Moreover, it would be even nice to me
>> 1) to write down this issue and to try to solve it in the next RTEMS
>> versions or,
>> 2) if it is somehow already possible, to show the steps to generate a
>> RTEMS application on a Windows host in an ELF format.
>> Should the Rtems community solve this issue, I'd be very grateful.
> How about you to file a PR at https://www.rtems.org/bugzilla, providing
> an example to reproduce the issues you are referring to, such that
> people can investigate?
> Ralf
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
