Possible bug in libchip/i2c/spi-sd-card.c (my MMC/SD problem)
Gene Smith
gds at chartertn.net
Thu Jan 15 18:42:01 UTC 2009
I don't have a way to check or verify this right now but I may see the
reason for the problem I am having doing shell copies on my MMC cards.
In my previous email
http://www.rtems.com/ml/rtems-users/2009/january/msg00078.html
I mentioned that 4 sectors (flash blocks) were written sequentially that
should have been scattered about in flash. Only the first one was at the
right place (the first FAT entry).
Also in this email, before I had a clue as to what I was seeing, I
reported 4 multiple blocks being written on file copy and the last
contained the copied file data:
data:http://www.rtems.com/ml/rtems-users/2009/january/msg00040.html
In both cases I think I am seeing the same thing.
The multiple block write occurs in spi-sd-card.c in function
sd_card_disk_block_write(..., r) where prm r is a struct/array of
scattered buffers (each at a random address). There are 4 block to be
written at address 0x200 (main FAT), 0x1ec0 (redundant FAT), 0x3d600
(root dir entry) and 0x41600 (cluster 2 with file data). Since there are
4 buffers (r->bufnum > 1) in the scatter array, a multiple block write
to MMC/SD is selected. The multiple write sets the starting address to
the first block (0x200) and writes all 4 blocks back to back beginning
at that address, which is wrong in this case. That's why my blocks end
up in the FAT area instead of at the right place.
So, unless the blocks are known to be truly sequential and not scattered
or random, only then should the multiple blocks method be used. I don't
know if there is a way to know without parsing the scatter array each
time. So it might be better (but slower) to always just use single block
write method multiple times if bufnum > 1.
Again, this is a theory that has yet to be verified.
-gene
