Problems with the debug information and C++
Ralf Corsepius ralf.corsepius at rtems.org
Thu Jan 22 13:49:59 UTC 2009
Without having looked into details, some random comments interspersed:
Sebastian Huber wrote:
> Hi,
> Command line:
> powerpc-rtems4.10-gcc test.cpp -lstdc++ && objdump -W a.out > /dev/null
This compiler call is invalid.
You _must_ use *-g++ to link c++ code - It would be a random accident,
should this example work.
> Output:
> Like in the previous mail.
>> There are many more warnings but they differ only in the numbers.  The
>> error and the overlap warning is new in 4.9 and CVS HEAD.  I noticed
>> this also on m68k.  Is this something that may cause harm?
> One of our customers reported that he cannot debug his application with his
> debugger.
What is "his debugger"?
> The support of the debugger vendor confirmed problem reports from
> various customers with GCC version 4.3.2.
Well, ... that's the usual excuse of debugger vendors utilize. I
wouldn't give much about it ;)
I am not aware about any particular gcc-4.3.2 debug format specific
change. Only the usual "imperfection" of SW.
> Does anyone know if this is more
> likely a RTEMS or GCC problem?
There is nothing special about powerpc-rtems-GCC. It's more or less a
vanilla powerpc-elf GCC.
> I am unsure if I should write a GCC bug report.
I'd recommend to ask on the GCC list, ideally accompanied with a code
example. It would not be the first time, somebody is facing an issue
some specialist is very familiar with.
Ralf
