Problems with the debug information and C++
Thu Jan 22 13:54:16 UTC 2009
Ralf Corsepius wrote:
> Without having looked into details, some random comments interspersed:
> Sebastian Huber wrote:
>> Hi,
>> Command line:
>> powerpc-rtems4.10-gcc test.cpp -lstdc++ && objdump -W a.out > /dev/null
> This compiler call is invalid.
> You _must_ use *-g++ to link c++ code - It would be a random accident,
> should this example work.
Changed it to:
powerpc-rtems4.8-g++ test.cpp && objdump -W a.out > /dev/null
powerpc-rtems4.9-g++ test.cpp && objdump -W a.out > /dev/null
powerpc-rtems4.10-g++ test.cpp && objdump -W a.out > /dev/null
Output is the same.
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
