Powerpc: bsp_reset()
Till Straumann strauman at slac.stanford.edu
Tue Jan 27 05:16:38 UTC 2009
Matt Rippa wrote:
> Hi Kate -
> Bits [7:3] are reserved defaulting to 00100, and bit 2 is read
> only so I don't think it matters. But I agree it was sloppy.
> Interesting though, the Data Sheet I found was the W83C553F. It
> specifies bit 1 as "Alt A20", and Bit 0 as "Hot Reset". I've
> only tried setting bit 1. Does this make sense to anyone?
Maybe it late at night (either for me or for you) but
I'd say outb(1,0x92) is setting bit 0...
T.
> Thanks,
> -Matt
> Feng, Kate wrote:
>> Hi Matt,
>> It seems that your original  plan was to do
>> outb(inb(0x92) | 1, 0x92);
>> I do not have datasheet for those boards.
>> Anyway, it probably does not make a differnce since you are
>> resetting the board.
>> Kate
>> ________________________________
>> From: rtems-users-bounces at rtems.org on behalf of Matt Rippa
>> Sent: Mon 1/26/2009 8:16 PM
>> To: rtems-users at rtems.org
>> Subject: Powerpc: bsp_reset()
>> Hi -
>> For older mvme boards I noticed bsp_reset() was not actually
>> resetting my board. Tracked this down to
>> libbsp/powerpc/shared/console/reboot.c and propose the following
>> patch.
>> I've also submitted PR 1362 and updated the wiki for the
>> mvme2700, although I think this affects mvme2300--mvme2700.
>> Thanks for helping Till,
>> -Matt
>> /tmp/rtems-4.9.1/c/src/lib/libbsp/powerpc/shared/console/reboot.c
>>    2008-10-23 03:45:55.000000000 -1000
>> +++ reboot.c    2009-01-26 09:30:30.295646000 -1000
>> @@ -16,10 +16,14 @@
>>     printk("Printing a stack trace for your convenience :-)\n");
>>     CPU_print_stack();
>>     /* shutdown and reboot */
>> -#if defined(BSP_KBD_IOBASE)
>> -  kbd_outb(0x4, 0xFE);      /* use keyboard controler to do the
>> job... */
>> -#endif
>>   #if defined(mvme2100)
>>     *(unsigned char*)0xffe00000 |= 0x80;
>> +#else
>> +   /* Memory-mapped Port 92 PIB device access
>> +   *(unsigned char*)0x80000092 |= 0x01;
>> +   outb(1, 0x92);
>>   #endif
>>   } /* bsp_reset */
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
