RTEMS running the examples with an rpm installation
Tue Jan 13 14:10:07 UTC 2009
Gene Smith wrote:
> Pool, LC, Mr <14117614 at sun.ac.za> wrote:
>> Hi...
>> I've installed the RTEMS package on scientific linux via rpm's. I would
> like to test my installation running the examples that I got from the
> source rtems-4.10. The installation is also rtems-4.10. The problem is
> that I'm not sure what is meant by the environment variable, export
> RTEMS_MAKEFILE_PATH=<INSTALLATION_POINT>/<CPU>-rtems/<BOARD_SUPPORT_PACKAGE>,
> where the problem is the BOARD_SUPPORT_PACKAGE....
>> so the INSTALLATION_POINT= /opt/rtems-4.10
>> the CPU-rtems =  m32c-rtems4.10
>> but the BOARD_SUPPORT_PACKAGE = ?   "(m32c)"
>> This is the current directory view of say m32c...
Gene is right in what he is saying.
I want to warn you on the m32c.  It is a new port
and incomplete.  It does not currently support interrupts.
We would welcome the addition of interrupt support.
And to make matters worse, you need to be using gdb
CVS to run the examples not gdb 6.8.
$ m32c-rtems4.10-run m32c-m32csim-ticker.ralf
unknown m32c machine type 0x0
NULL pointer dereference
But it runs with my locally built gdb from CVS.
I usually recommend sparc/sis as an easy first BSP.
This page should help you with that BSP:
http://www.rtems.org/wiki/index.php/Quick_Start
>> pwd = /opt/rtems-4.10/m32c-rtems4.10
>> total 24
>> drwxr-xr-x 2 root root 4096 Jan 13 09:30 bin
>> drwxr-xr-x 5 root root 4096 Jan 13 09:30 include
>> drwxr-xr-x 4 root root 4096 Jan 13 09:30 lib
>> uhm any help would be great!!!
> I'll give it a shot. On my system my cpu is arm and bsp is csb337 so I
> have RTEMS_MAKEFILE_PATH set to /opt/rtems-4.9/arm-rtems4.9/csb337
> So BOARD_SUPPORT_PACKAGE for me is csb337 and <CPU>-rtems is
> arm-rtems4.9. Is this what you are asking?
> rtems-users mailing list
> rtems-users at rtems.com
