Rtems for a space project
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Jan 13 15:42:02 UTC 2009
Massimo Tipaldi wrote:
> Joel,
> I have downloaded QEMU from http://www.h7.dion.ne.jp/~qemu-win/.
> The file is qemu-0.9.0-windows.zip.
> Window version of QEMU: 0.9.0
> GNU GRUB version 1.94
I found that he has a new site with 0.9.1. He also
states that there was a version of 0.9.0 with a virus
attached. Because of this I am not installing 0.9.0
on my PC.
Try this page for 0.9.1.
http://homepage3.nifty.com/takeda-toshiya/qemu/
I used a ticker.exe (not ticker.ralf) and it booted fine with
the floppy image I used on linux.
ticker.ralf is a netboot image and apparently grub doesn't
like it.
I am going to be off this afternoon but if you can't get it to
run, email me your ticker.exe (compressed) and I will
try it locally.
--joel
> Massimo
>>> OK, I experienced myself that the Rtems makefiles are not correct
>>> ...but I should solve my issue, if it is possible.
>> I have been unable to duplicate any problem you have reported.
>> I don't know what is going wrong with your install.
>>> In any case, I'd like to know if:
>>> 1) someone has considering compiling an easy RTEMS application on
>>> Windows PC for i386(and not on a Linux PC, where I konw that it works)
>> It works on Windows but the main developers use Windows
>> as little as possible. The Eclipse plugin work was initially
>> done on Windows.
>>> 2) how this application can be make compliant with Grub (Elf
>>> file/multiboot specification).
>> You have at least 4 variables. I suspect your qemu/grub
>> setup. Can you tell me where you got your Windows version
>> of Qemu and what version it is. The one I see is not that latest
>> version and that by itself is enough to cause issues.
>> With that, I will run the executable and grub setup I have
>> on Linux on Windows so we can be sure that a known good
>> RTEMS executable can even run on the version of qemu
>> you have.
>> I do LOTS of testing on qemu/rtems/grub/linux. This is
>> how the i386-rtems tool test results are generated. That is
>> ~80K tests in batch mode. There are many Windows users.
>> So we need to reduce variables. First order is to split it
>> between rtems/tools and qemu.
>>> I insist on these points:
>>> 1) the Grub set-up is correct and the source of this failure is
>>> somewhere else (the hello.exe in testsuites/samples works)
>>> 2) I have followed all the Rtems wiki instructions to install the
>>> toolchains, rtems and so on; the packages have been downloaded
>>> following the links shown on Rtems wiki.
>>> Can I hope to solve this issue? Is Rtems today mature for Windows?
>>> Massimo
>>> rtwas ha scritto:
>>>> Hello,
>>>> Ralf Corsepius wrote:
>>>>> Makefile.inc is a different class of problem.
>>>>> My personal answer to all Makefile.inc related problems: I refuse to
>>>>> answer any Makefile.inc related issues, because I consider RTEMS
>>>>> Makefile-template system to be mal-designed kid-stuff, RTEMS should
>>>>> have stopped dropped a long time ago ;)
>>>> I was never comfortable with having the make-system *hidden* from me.
>>>> I made
>>>> an attempt to be a *good boy* and use it but couldn't get it to work
>>>> for my particular
>>>> build so I ended up reverse engineering it (Makefile templates etc.)
>>>> and writing my
>>>> own (Makefile system) from scratch.
>>>> Robert W.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
