Tilde seen as backspace in shell
Fri Jan 23 00:13:50 UTC 2009
Gene Smith wrote:
> I don't know if this is a bug or a feature I don't understand about
> terminal protocols or shells.
Bug.
> When I enter a tilde (~) the effect is the
> same as hitting backspace. This makes it impossible to enter a filename
> that contains a ~ which is how LFNs are now displayed when they exist in
> the filesystem.
> I have seen this with RTEMS shell running in linux xterms, cygwin rxvt,
> XP cmd window and Ed Sutter's uCon. Changing terminal setting make no
> difference.
> Looking with wireshark and telnet filter I see tilde go out. But then an
> echo of \b  (0x07, backspace) is send by RTEMS and in the next packet I
> see 0x20,0x07 (space backspace). So the net result of typing tilde is a
> backspace: (backspace, space, backspace).
> Looking in cpukit/libmisc/shell/shell.c I found where ~ (Ascii value
> 0x7e) is converted to a backspace. Backspace and DEL are also treated
> this way but I guess that is OK.
Bug.
> Also, near the bottom of the same function (rtems_shell_line_editor())
> at the default of the case only chars between space and 'z' are printed.
> For some reason {|}~ are excluded from printing.
> So to allow ~ to act as a regular char, I had to exclude it from being
> converted to backspace and open up the allowed ascii range to include tilde.
Fixed in CVS. Please update or get a copy and place in your source tree.
Joel, is this change ok for the 4.9 branch ?
Regards
