Powerpc: bsp_reset()
Feng, Kate
feng at bnl.gov
Tue Jan 27 02:45:23 UTC 2009
Hi Matt,
It seems that your original plan was to do
outb(inb(0x92) | 1, 0x92);
I do not have datasheet for those boards.
Anyway, it probably does not make a differnce since you are
resetting the board.
Kate
________________________________
From: rtems-users-bounces at rtems.org on behalf of Matt Rippa
Sent: Mon 1/26/2009 8:16 PM
To: rtems-users at rtems.org
Subject: Powerpc: bsp_reset()
Hi -
For older mvme boards I noticed bsp_reset() was not actually
resetting my board. Tracked this down to
libbsp/powerpc/shared/console/reboot.c and propose the following
patch.
I've also submitted PR 1362 and updated the wiki for the
mvme2700, although I think this affects mvme2300--mvme2700.
Thanks for helping Till,
-Matt
/tmp/rtems-4.9.1/c/src/lib/libbsp/powerpc/shared/console/reboot.c
2008-10-23 03:45:55.000000000 -1000
+++ reboot.c 2009-01-26 09:30:30.295646000 -1000
@@ -16,10 +16,14 @@
printk("Printing a stack trace for your convenience :-)\n");
CPU_print_stack();
/* shutdown and reboot */
-#if defined(BSP_KBD_IOBASE)
- kbd_outb(0x4, 0xFE); /* use keyboard controler to do the
job... */
-#endif
#if defined(mvme2100)
*(unsigned char*)0xffe00000 |= 0x80;
+#else
+ /* Memory-mapped Port 92 PIB device access
+ *(unsigned char*)0x80000092 |= 0x01;
+ outb(1, 0x92);
#endif
} /* bsp_reset */
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
