Multiprocessor problems
Daniel Hellstrom
daniel at gaisler.com
Wed Jul 1 13:08:39 UTC 2009
Hi Joel,
I have attached a patch which introduces a new "early" MP initialization
routine. This works for SPARC/LEON3 MP.
Daniel
Joel Sherrill wrote:
> Can you provide a patch Daniel?
> Daniel Hellstrom wrote:
>> Hi,
>> The problem seems to be the initialization of _Objects_Local_node in
>> multiprocessor enabled kernels. Since the _MPCI_Initialization()
>> initializes _Objects_Local_node later than the first semaphores and
>> tasks are created, this makes the IDs assigned to created objects
>> incorrect.
>> In single processor systems the _Objects_Local_node is a constant set
>> to 1, but in multiprocessor systems it is initially set to zero and
>> then initialized by _MPCI_Initialization().
>> The problem you experience is probably the same problem I ran into
>> this week when running on a dual core SPARC/LEON3 system. Two tasks
>> are created before the node number is setup correctly. See below
>> print out from GRMON after breaking at Init():
>> grmon> thread info
>> Name | Type | Id | Prio | Time (h:m:s) | Entry
>> point | PC | State
>> Int. | internal | 0x09000001 | 255 | 0.000000 |
>> ?? | 0x0 | READY
>> Int. | classic | 0x09000002 | 0 | 0.000000 | ??
>> | 0x0 | Wsem
>> * UI1 | classic | 0x0a010001 | 1 | 0.000000 |
>> RAM_END | 0x40001368 Init +
>> 0x4 | READY
>> As you can see the node number is 0 rather than 1 or 2 in the ID field.
>> The bug appears when the first MPCI packet is received on the target
>> node, the ISR calls _MCPI_Announce which tries to release a
>> semaphore, the blocked thread are thought to be global and the system
>> crashes. The function deciding if it is a global or local object
>> simply checks if they are of the same node, not if the node number is
>> zero.
>> RTEMS_INLINE_ROUTINE bool _Objects_Is_local_node(
>> uint32_t node
>> return ( node == _Objects_Local_node );
>> To test that this theory holds I changed the declaration of
>> _Objects_Local_node to extern instead of SCORE_EXTERN, and declared
>> it in my project initialy initialized to the node number. The LEON3
>> dual core system now works and I have successfully managed to get
>> semaphores and tasks interacting between the two nodes.
>> uint16_t _Objects_Local_node = CONFIGURE_MP_NODE_NUMBER;
>> I suggest that the initialization of _Objects_Local_node is moved to
>> be initialized earlier.
>> Regards,
>> Daniel Hellstrom
>>> Roger Dahlkvist wrote:
>>>> Hi,
>>>> I'm using a timer ISR polling method checking for new messages from
>>>> other nodes. Unfortunately the system crashes as soon as
>>>> rtems_multiprocessing_announce is called.
>>> There are no interrupts enabled until the initialization task is
>>> switched
>>> in.
>>> I have wondered if it wouldn't make sense to have the MP initialization
>>> sycnhronization done either explicitly by the application (like
>>> initialization
>>> of TCP/IP) or implicitly by the init thread like C++ global
>>> constructors.
>>> You can try moving this code from exinit.c to threadhandler.c where and
>>> protect it somehow from being executed more than once.
>>> #if defined(RTEMS_MULTIPROCESSING)
>>> if ( _System_state_Is_multiprocessing ) {
>>> _MPCI_Initialization();
>>> _MPCI_Internal_packets_Send_process_packet(
>>> MPCI_PACKETS_SYSTEM_VERIFY
>>> #endif
>>> Then you will at least be able to get your interrupts and call MP
>>> announce
>>> to complete system initialization.
>>>> However, rtems_multiprocessing_announce works just fine if it's
>>>> called just after the initialization phase, before the
>>>> initinitialization task is started. That's really strange.
>>>> So for example, if I make one node get initialized and started
>>>> faster than the other node (using less drivers etc), I'll be able
>>>> to create global objects. and as long as the other node has not
>>>> started the initialization task, the message is received and the
>>>> global objects table is updated, so it can be identified later on.
>>>> But I can't use them since furter calls to
>>>> rtems_multiprocessing_announce will fail.
>>>> At this point I feel like I have tested just about everything, with
>>>> no luck. It's urgent that I get MP to work properly. I'm using Nios
>>>> II processors and I have defined my own MPCI routines. I'm
>>>> confident that they work properly and I have verified that the
>>>> system crashes before they are even invoked.
>>>> Is there anyone with MP experience who might have a clue of what's
>>>> causing my problems? Any help is MUCH appreciated.
>>>> //Roger
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20090701/9fc48587/attachment.ksh>
