Exception ??
Daron Chabot daron.chabot at gmail.com
Wed Jul 1 15:29:25 UTC 2009
Exception 3 is a breakpoint exception on the i386 :-)
"UI1"... That sounds like the "Init" thread. You are generating a
breakpoint from Init...
FYI, I have used these commands to initialize the remote-debugging
stub and stop program execution, waiting for the host gdb session to
connect (over rs-232):
    init_remote_gdb();
    rtems_task_wake_after(25); /* 1 tick == 10 ms */
    breakpoint();
-- dc
On Wed, Jul 1, 2009 at 9:59 AM, lee<funnyvoice at tlabs.ac.za> wrote:
> Hi All again....
> Im running a very simple test program, called hello.exe...
> So I got the shell working.. thanx again... then tried the gdb... got
> gdb compiled works fine.... but when I run the target after compiling it
> i get 0x0a10003 thread 3 exception error? The name of this thread is
> "UI1"... but cant seem to find this anywhere in source... I grepped just
> about the entire source tree.... any idea what this could be...???
> This happens when I invoke :
> set_debug_traps();
> Here is the startup:
>  i386_stub_glue_init(BSP_UART_COM1);
>  /* Init GDB stub itself */
>  //set_debug_traps();
>   * Init GDB break in capability,
>   * has to be called after
>   * set_debug_traps
>  i386_stub_glue_init_breakin();
> I've put a breakpoint somewhere in the source.... anyone have similar
> problem...
> Kind Regards
> Lee
> rtems-users mailing list
> rtems-users at rtems.org
