Multiprocessor problems
Daniel Hellstrom daniel at gaisler.com
Sat Jul 4 14:58:38 UTC 2009
Joel Sherrill wrote:
> Daniel Hellstrom wrote:
>> Hi Joel,
>> I have attached a patch which introduces a new "early" MP
>> initialization routine. This works for SPARC/LEON3 MP.
> Committed to the head.  Does this also need to go on the 4.9 branch?
Have not investigated this, am on my summer holidays now until 1:st aug.
> What were you testing with?
SPARC/LEON3 Dual Core, 256MB SDRAM, 5 Timers, 2 UARTs, PCI and Ethernet.
Booting from RAM using GRMON, and from FLASH using mkprom.
Daniel
> --joel
>> Daniel
>>> Can you provide a patch Daniel?
>>>> Hi,
>>>> The problem seems to be the initialization of _Objects_Local_node
>>>> in multiprocessor enabled kernels. Since the _MPCI_Initialization()
>>>> initializes _Objects_Local_node later than the first semaphores and
>>>> tasks are created, this makes the IDs assigned to created objects
>>>> incorrect.
>>>> In single processor systems the _Objects_Local_node is a constant
>>>> set to 1, but in multiprocessor systems it is initially set to zero
>>>> and then initialized by _MPCI_Initialization().
>>>> The problem you experience is probably the same problem I ran into
>>>> this week when running on a dual core SPARC/LEON3 system. Two tasks
>>>> are created before the node number is setup correctly. See below
>>>> print out from GRMON after breaking at Init():
>>>> grmon> thread info
>>>>   Name | Type     | Id         | Prio | Time (h:m:s)  | Entry
>>>> point             | PC                                           |
>>>> State
>>>>   Int. | internal | 0x09000001 |  255 |      0.000000 |
>>>> ??               | 0x0           | READY
>>>>   Int. | classic  | 0x09000002 |    0 |      0.000000 | ??
>>>>                 | 0x0              | Wsem
>>>> * UI1  | classic  | 0x0a010001 |    1 |      0.000000 |
>>>> RAM_END                 | 0x40001368 Init +
>>>> 0x4                        | READY
>>>> As you can see the node number is 0 rather than 1 or 2 in the ID
>>>> field.
>>>> The bug appears when the first MPCI packet is received on the
>>>> target node, the ISR calls _MCPI_Announce which tries to release a
>>>> semaphore, the blocked thread are thought to be global and the
>>>> system crashes. The function deciding if it is a global or local
>>>> object simply checks if they are of the same node, not if the node
>>>> number is zero.
>>>> RTEMS_INLINE_ROUTINE bool _Objects_Is_local_node(
>>>>   uint32_t   node
>>>>   return ( node == _Objects_Local_node );
>>>> To test that this theory holds I changed the declaration of
>>>> _Objects_Local_node to extern instead of SCORE_EXTERN, and declared
>>>> it in my project initialy initialized to the node number. The LEON3
>>>> dual core system now works and I have successfully managed to get
>>>> semaphores and tasks interacting between the two nodes.
>>>> uint16_t _Objects_Local_node = CONFIGURE_MP_NODE_NUMBER;
>>>> I suggest that the initialization of _Objects_Local_node is moved
>>>> to be initialized earlier.
>>>> Regards,
>>>> Daniel Hellstrom
>>>>> Roger Dahlkvist wrote:
>>>>>> Hi,
>>>>>> I'm using a timer ISR polling method checking for new messages
>>>>>> from other nodes. Unfortunately the system crashes as soon as
>>>>>> rtems_multiprocessing_announce is called.
>>>>> There are no interrupts enabled until the initialization task is
>>>>> switched
>>>>> in.
>>>>> I have wondered if it wouldn't make sense to have the MP
>>>>> initialization
>>>>> sycnhronization done either explicitly by the application (like
>>>>> initialization
>>>>> of TCP/IP) or implicitly by the init thread like C++ global
>>>>> constructors.
>>>>> You can try moving this code from exinit.c to threadhandler.c
>>>>> where and
>>>>> protect it somehow from being executed more than once.
>>>>>  #if defined(RTEMS_MULTIPROCESSING)
>>>>>    if ( _System_state_Is_multiprocessing ) {
>>>>>      _MPCI_Initialization();
>>>>>      _MPCI_Internal_packets_Send_process_packet(
>>>>>        MPCI_PACKETS_SYSTEM_VERIFY
>>>>>  #endif
>>>>> Then you will at least be able to get your interrupts and call MP
>>>>> announce
>>>>> to complete system initialization.
>>>>>> However, rtems_multiprocessing_announce works just fine if it's
>>>>>> called just after the initialization phase, before the
>>>>>> initinitialization task is started. That's really strange.
>>>>>> So for example, if I make one node get initialized and started
>>>>>> faster than the other node (using less drivers etc), I'll be able
>>>>>> to create global objects. and as long as the other node has not
>>>>>> started the initialization task, the message is received and the
>>>>>> global objects table is updated, so it can be identified later
>>>>>> on. But I can't use them since furter calls to
>>>>>> rtems_multiprocessing_announce will fail.
>>>>>> At this point I feel like I have tested just about everything,
>>>>>> with no luck. It's urgent that I get MP to work properly. I'm
>>>>>> using Nios II processors and I have defined my own MPCI routines.
>>>>>> I'm confident that they work properly and I have verified that
>>>>>> the system crashes before they are even invoked.
>>>>>> Is there anyone with MP experience who might have a clue of
>>>>>> what's causing my problems? Any help is MUCH appreciated.
>>>>>> //Roger
>>>>>> _______________________________________________
>>>>>> rtems-users mailing list
>>>>>> rtems-users at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
