[GSOC]Dynamic object file loading:basic working version
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Thu Jul  9 19:57:17 UTC 2009
Good job!
Random questions:
+ unload_library isn't implemented yet in the linker.c
+ does the loaded library get a call to initialize itself?
+ will you need some help getting a comparable demo
   application on RTEMS?
+ The code uses at least pthread_mutex.  This means that
   it will require POSIX to be enabled in RTEMS.  Is this the
   only thing forcing RTEMS POSIX thread support to be
   enabled?  [NOTE: I don't know if this is a big deal or not.
   at this point, it is just a requirement on the code.]
+ Is this really as self-contained as it looks? :-D
And can you update the google docs page that has
the general SoC Status for all RTEMS projects?  If
I didn't send you permission, just ping me and I
will add you.
--joel
JiSheng Zhang wrote:
> Hi all,
> Now basic symbol resolving and relocation works! The code is attached.
> For test just make and then ./demo -l ./t.o -s get. If you should see
> something like "******5******" plus various debug message.
> Explanation:
> t.c looks like this:
> int ttt=5;
> int get()
>        return ttt;
> so t.o should have at least one relocation and two symbols. readelf -S
> t.o and readelf -s t.o prove this.
> the dynamic linker load t.o and parsing it, then it loading all needed
> sections, finally it will do symbol resolving and relocation.
> For test I just point entry to the start of ".text" that is get
> function, then call this  function via entry, we should get the
> result:5
> TODO next week:
> 1.lookup external symbol which is exported by demo
> 2.support symbol resolving exported by object file which is dynamic loaded
> Regards,
> JiSheng
