Dynamic scheduling
Nasim Zehra nasimz at lums.edu.pk
Fri Jul 17 06:57:32 UTC 2009
 like EDF, Minimum Laxity first.Actually i m having observation that rtems has only rate monotonic .static scheduling scheme, manager.May be it does not support dynamic one?I guess timer or clock directives are helpful in this regard, but i am having problem using timer directive..that what should be written in place of *user_data when timer is fired.Moreover whether should we create timer directive in main "init" function or should we create and delete then like rate monotonic periods inside the task ,mentioned in the example of rate monotonic manager.
nasim
________________________________________
From: Thomas Doerfler [Thomas.Doerfler at embedded-brains.de]
Sent: Friday, July 17, 2009 12:49 PM
To: Nasim Zehra
Cc: rtems-users at rtems.org
Subject: Re: Dynamic scheduling
Hi,
what exactly do you call "dynamic scheduling"? The term seems a bit
"open" to me, but maybe I am simpy ignorant :-)
wkr,
Thomas.
Nasim Zehra wrote:
> Does rtems support dynamic scheduling??if yes what managers are useful for this purpose?
> nasim
> rtems-users mailing list
Embedded Brains GmbH
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
