CPU_USAGE_REPORT() Problem
Fri Jul 17 12:36:19 UTC 2009
Nasim Zehra wrote:
> Hi,
>   i am having five tasks and i want cpu usage report table.
> just after five tasks creation ,i am having table like that
>  ID        NAME     SECONDS   PERCENT
> 0x09010001   IDLE     0.000000    0.000
> 0x0A010001   UI1      0.001260  100.000
> 0x0A010002   TA1      0.000000    0.000
> 0x0A010003   TA2      0.000000    0.000
> 0x0A010004   TA3      0.000000    0.000
> 0x0A010005   TA4      0.000000    0.000
> 0x0A010006   TA5      0.000000    0.000
> ----OK bcz idle is by defaul..rest of having 0 exec time..good......But don't know what UI1 is ??????
> ok then after execution of all the tasks i am having table like that
> 0x0A010001   UI1      0.000787    0.024
> 0x0A010002   TA1      2.216917   70.157
> 0x0A010004   TA3      0.001027    0.032
> --still made at UI1..what is it? and where TA2 AND TA4 have gone?????
UI1 is the default name of the user initialization task.
Tasks missing indicates that they have exited or
been deleted.
The percentage doesn't get close to 100% because the
report wasn't reset after they were deleted.
With no source code, this is an educated guess on TA2 and TA4
> although i  tried to solve this problem by defining array of task name and id of size 7 instead of five.I know it is ridiculus to do this...it should have no effect on this problem.any solution?
Array is just used by the tests.  Name is stored internal to TCB,
> nasim
> rtems-users mailing list
> rtems-users at rtems.org
