[GSOC2009] Frame buffer support for PXA255 target of Skyeye simulator
xi yang
hiyangxi at gmail.com
Sun Jul 26 13:13:26 UTC 2009
Hi Joel, please adding "fb.h" and "skyeye_fb.h" to
"libbsp/arm/gumstix/fb/fb.h" "libbsp/arm/gumstix/fb/skyeye_fb.h".
Enable_lcd.patch is for gcc-testing
frambuffer.patch is for RTEMS
* Enable LCD option for gumstix of gcc-tesging
Index: sim-scripts/gumstix.in
RCS file: /usr1/CVS/gcc-testing/sim-scripts/gumstix.in,v
retrieving revision 1.4
diff -u -r1.4 gumstix.in
--- sim-scripts/gumstix.in 10 Jul 2009 17:07:22 -0000 1.4
+++ sim-scripts/gumstix.in 26 Jul 2009 13:07:18 -0000
@@ -43,6 +43,7 @@
mem_bank: map=I, type=RW, addr=0xB0000000, size=0x100000
mem_bank: map=I, type=RW, addr=0x40000000, size=0x4C000000
shutdown_device: addr=0xb0000000, max_ins=${limit}0000000
+lcd:state=on,type=pxa,mod=gtk
EOF
if [ ${coverage} = yes ] ; then
echo "code_coverage: state=on, filename=${2}.cov, start=0xA0000000,
end=0xA4000000"
*Frame buffer support for pxa255 target of SKYEYE simulator
Index: c/src/lib/libbsp/arm/gumstix/ChangeLog
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/ChangeLog,v
retrieving revision 1.7
diff -u -r1.7 ChangeLog
--- c/src/lib/libbsp/arm/gumstix/ChangeLog 16 Jul 2009 23:18:12 -0000 1.7
+++ c/src/lib/libbsp/arm/gumstix/ChangeLog 26 Jul 2009 13:04:27 -0000
@@ -1,3 +1,9 @@
+2009-07-26 Xi Yang <hiyangxi at gmail.com>
+ * Makefile.am: Add fb/fb.c
+ * preinstall.am: Install skyeye_fb.h
+ * fb/fb.c, fb/skyeye_fb.h: Framebuffer support for skyeye simulator
+ * startup/memmap.c: Change the size of Map I/O to 1216M
2009-07-16 Joel Sherrill <joel.sherrill at oarcorp.com>
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
Index: c/src/lib/libbsp/arm/gumstix/Makefile.am
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/Makefile.am,v
diff -u -r1.4 Makefile.am
--- c/src/lib/libbsp/arm/gumstix/Makefile.am 10 Jul 2009 17:06:37 -0000 1.4
+++ c/src/lib/libbsp/arm/gumstix/Makefile.am 26 Jul 2009 13:04:27 -0000
@@ -40,6 +40,8 @@
libbsp_a_SOURCES += console/uarts.c ../../shared/console.c
#abort
libbsp_a_SOURCES += ../shared/abort/abort.c
+#framebuffer
+libbsp_a_SOURCES += fb/fb.c
libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/clock.rel \
Index: c/src/lib/libbsp/arm/gumstix/preinstall.am
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/preinstall.am,v
retrieving revision 1.1
diff -u -r1.1 preinstall.am
--- c/src/lib/libbsp/arm/gumstix/preinstall.am 4 Jun 2009 16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/preinstall.am 26 Jul 2009 13:04:27 -0000
@@ -41,6 +41,10 @@
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
+$(PROJECT_INCLUDE)/rtems/skyeye_fb.h: fb/skyeye_fb.h
$(PROJECT_INCLUDE)/rtems/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/skyeye_fb.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/skyeye_fb.h
$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
Index: c/src/lib/libbsp/arm/gumstix/startup/memmap.c
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/startup/memmap.c,v
diff -u -r1.1 memmap.c
--- c/src/lib/libbsp/arm/gumstix/startup/memmap.c 4 Jun 2009 16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/startup/memmap.c 26 Jul 2009 13:04:27 -0000
@@ -12,7 +12,7 @@
mmu_sect_map_t mem_map[] = {
/* <phys addr> <virt addr> <size> <flags> */
- {0x40000000, 0x40000000, 20, MMU_CACHE_NONE}, /*Map I/O*/
+ {0x40000000, 0x40000000, 1216, MMU_CACHE_NONE}, /*Map I/O*/
{0xA0000000, 0x00000000, 1, MMU_CACHE_NONE}, /*sram*/
{0xA0000000, 0xA0000000, 64, MMU_CACHE_WBACK}, /* SDRAM */
{0x00000000, 0x00000000, 0, 0} /* The end */
Index: c/src/lib/libcpu/arm/ChangeLog
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/arm/ChangeLog,v
retrieving revision 1.61
diff -u -r1.61 ChangeLog
--- c/src/lib/libcpu/arm/ChangeLog 17 Jul 2009 13:52:16 -0000 1.61
+++ c/src/lib/libcpu/arm/ChangeLog 26 Jul 2009 13:04:28 -0000
@@ -1,3 +1,6 @@
+ * pxa255/include/pxa255.h: Add LCD related registers
2009-07-15 Sebastian Huber <sebastian.huber at embedded-brains.de>
* Makefile.am: Removed references to deleted file
Index: c/src/lib/libcpu/arm/pxa255/include/pxa255.h
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/arm/pxa255/include/pxa255.h,v
retrieving revision 1.3
diff -u -r1.3 pxa255.h
--- c/src/lib/libcpu/arm/pxa255/include/pxa255.h 10 Jul 2009 15:34:12 -0000 1.3
+++ c/src/lib/libcpu/arm/pxa255/include/pxa255.h 26 Jul 2009 13:04:28 -0000
@@ -106,4 +106,24 @@
#define PMC_PMNC_CCD (0x01 << 3)
#define PMC_PMNC_PCD (0x01 << 4)
+/*LCD*/
+#define LCCR0 (*(volatile word_t *)(0x44000000))
+#define LCCR1 (*(volatile word_t *)(0x44000004))
+#define LCCR2 (*(volatile word_t *)(0x44000008))
+#define LCCR3 (*(volatile word_t *)(0x4400000C))
+#define FDADR0 (*(volatile word_t *)(0x44000200))
+#define FSADR0 (*(volatile word_t *)(0x44000204))
+#define FIDR0 (*(volatile word_t *)(0x44000208))
+#define LDCMD0 (*(volatile word_t *)(0x4400020C))
+#define FDADR1 (*(volatile word_t *)(0x44000210))
+#define FSADR1 (*(volatile word_t *)(0x44000214))
+#define FIDR1 (*(volatile word_t *)(0x44000218))
+#define LDCMD1 (*(volatile word_t *)(0x4400021C))
+#define LCCR0_ENB 0x00000001
+#define LCCR1_PPL 0x000003FF
+#define LCCR2_LPP 0x000003FF
+#define LCCR3_BPP 0x07000000
#endif
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090726/a54a5647/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090726/a54a5647/attachment-0001.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090726/a54a5647/attachment-0002.bin>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20090726/a54a5647/attachment-0003.bin>
