[GSOC2009]GUMSTIX(PXA255) BSP for RTEMS
xi yang hiyangxi at gmail.com
Thu Jun 4 14:08:46 UTC 2009
In gumstix_bsp.patch, I also delete some unused global variables in
bspstart.c of CSB337 BSP.
Regards
2009/6/5 xi yang <hiyangxi at gmail.com>:
> Hi, I work for project of GSOC2009. Here is a sample BSP for Gumstix
> with clock, uart, timer support.
> gumstix_bsp.patch is generated by cvs diff -uN
> You need place gumstix.cfg to ./make/custom/
> Extract gumstix.tar.gz to c/src/lib/libbsp/arm/
> Extract pxa255.tar.gz  to c/src/lib/libcpu/arm/
> gumstix.skyeye is configure file for skyeye simulator.
> With below patch for current version from SVN of skyeye project, you
> can use skeyey to run GUMSTIX bsp by ./skyeye -c gumstix.skyeye -e
> hello.exe (Please notice that when you execute ticker.exe, you have to
> wait for a long time since one tick of skyeye simulator is more slower
> than real hardware)
> Here is Skyeye patch(Maybe then have fixed in SVN)
> Index: device/nandflash/nandflash_smallblock.c
> --- device/nandflash/nandflash_smallblock.c     (revision 653)
> +++ device/nandflash/nandflash_smallblock.c     (working copy)
> @@ -516,7 +516,7 @@
>  #endif
>       nf->writebuffer=(u8*)malloc(dev->pagedumpsize);
>       //nf->memsize=528*32*4096;
> -       if ((nf->fdump= open(dev->dump, FILE_FLAG)) < 0)
> +       if ((nf->fdump= open(dev->dump, FILE_FLAG, FILE_MODE)) < 0)
>               free(nf);
>               printf("error open nandflash dump!\n");
> Index: device/nandflash/nandflash_smallblock.h
> --- device/nandflash/nandflash_smallblock.h     (revision 653)
> +++ device/nandflash/nandflash_smallblock.h     (working copy)
> @@ -27,6 +27,8 @@
>       #define FILE_FLAG   (O_RDWR | O_CREAT)
>  #endif
> +#define FILE_MODE (0x777)
>  #if (defined(__MINGW32__) || defined(__BEOS__))
>       #define POSIX_SHARE_MEMORY_BROKEN
>  #endif
> Index: memory/ram.c
> --- memory/ram.c        (revision 653)
> +++ memory/ram.c        (working copy)
> @@ -261,10 +261,10 @@
>       void * state;
>       switch(size){
>               case 8:
> -                       *(uint8_t *)value = (uint8_t)mem_read_byte (offset);
> +                       *value = (uint8_t)mem_read_byte (offset);
>                       break;
>               case 16:
> -                       *(uint16_t *)value =
> (uint16_t)mem_read_halfword(offset);
> +                       *value = (uint16_t)mem_read_halfword(offset);
>                       break;
>               case 32:
>                       *value = mem_read_word(offset);
> Regards
