netdemo failure question
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Jun 5 16:01:11 UTC 2009
Hi,
I am trying to update a NIC driver on an
existing BSP to support a new revision of
the board with new PHY. I used the microMonitor
code to get the PHY programming changes so
believe that is OK.
But the netdemo test fails on the 2nd bind attempt
with an EADDRINUSE error.
I checked the netdemo test on qemu and it behaves
correctly there. So there is something about this
BSP/NIC combination that is causing the error.
Any thoughts on what could be going wrong? Or
things to try to help debug it. This is a new
failure in my experience.
Thanks.
