timer server fire when with time adjust
Mon Jun 8 14:37:14 UTC 2009
Could be a bug.  Can you submit a small self-contained
test case?
--joel
Sergio Faustino wrote:
> Hi
> I've been looking at RTEMS for some time and now I have a doubt regarding
> the time management in RTEMS.
> The user manual states that:
> "The rtems_clock_set directive allows a task or an ISR to set the date and
> time maintained by RTEMS. If setting the date and time causes any
> outstanding timers to pass their deadline, then the expired timers will be
> fired during the invocation of the rtems_clock_set directive."
> From my understanding, this is also applicable to timers fired by the timer
> server.
> However, when I tested this, this does not appear to be working (on RTEMS 4.8.0).
> The test basically consists of creating and firing 3 timers with the
> rtems_timer_server_wake_when routine. When a rtems_clock_set is done (to a
> forward time) the timers should fire immediatly but, in reality, they fire later on.
> The same test with rtems_timer_fire_when (without the timer server) works
> properly.
> I guess this could be an RTEMS bug...
> Best Regards,
> Sergio Faustino
> rtems-users mailing list
> rtems-users at rtems.org
