sys/uio.h and errno.h required for networking?
Wed Jun 10 01:41:25 UTC 2009
Aaron J. Grier wrote:
>>> I needed the attached patch to get --enable-networking to compile on
>>> RTEMS CVS HEAD.  perhaps my newlib is out of date?
>> We did not see any issues here on most targets with the last build.
>> Check this page:
>>  http://www.rtems.org/ftp/pub/rtems/people/chrisj/pq/html/
>> Could you please supply your configure command ?
>   $ /projects/gsoc/rtems-cvs/rtems-head/configure --disable-itron --enable-tests --enable-posix --enable-cxx --enable-networking --enable-rtemsbsp=pc386 --target=i386-rtems4.10
This target is building ok and I am using daily with networking.
> I am compiling under NetBSD-5.
> newlib is -r newlib-1_17_0 from CVS.
> gcc is gcc-4_4-branch from SVN.
I suggest you use the source as found here:
  http://www.rtems.org/ftp/pub/rtems/SOURCES/4.10/
and see how you go.
Regards
