Bug found
Leon Pollak leonp at plris.com
Wed Jun 10 06:52:20 UTC 2009
On Tuesday June 9 2009, Thomas Dörfler wrote:
> Leon,
> the big question is, what is the definition of "clocks per usec". In
> your view, this is the bus clock, in the view implemented, it is the
> Timebase/DEC tick rate directly.
> Maybe this helps...
Thomas,
As all what you say, this definitely helps...:-))
Just, don't you think that the name of the variable is mistaking?
I understand "CPU clocks per usec" as the number of input frequency ticks in
one micro second.
How one can guess that it should be timebase clock AFTER prescaler?
But many thanks as usual...:-)
Leon
