[GSOC2009] Clean code of gumstix bsp and skyeye shut down support added
xi yang
hiyangxi at gmail.com
Sun Jun 14 12:11:49 UTC 2009
Joel, please remove bits.h in pxa255 directory since we don't need it.
Index: c/src/lib/libbsp/arm/gumstix/Makefile.am
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/Makefile.am,v
retrieving revision 1.1
diff -u -r1.1 Makefile.am
--- c/src/lib/libbsp/arm/gumstix/Makefile.am 4 Jun 2009 16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/Makefile.am 14 Jun 2009 12:05:47 -0000
@@ -21,38 +21,28 @@
nodist_include_HEADERS += ../../shared/include/coverhd.h
-EXTRA_DIST = start/start.S
-start.$(OBJEXT): start/start.S
- $(CPPASCOMPILE) -o $@ -c $<
+noinst_LIBRARIES = libbspstart.a
+libbspstart_a_SOURCES = ./start/start.S
project_lib_DATA = start.$(OBJEXT)
dist_project_lib_DATA += startup/linkcmds
-noinst_PROGRAMS += startup.rel
-startup_rel_SOURCES = ../../shared/bsplibc.c ../../shared/bsppost.c \
+noinst_LIBRARIES += libbsp.a
+libbsp_a_SOURCES =
+#startup
+libbsp_a_SOURCES += ../../shared/bsplibc.c ../../shared/bsppost.c \
../../shared/bsppredriverhook.c ../../shared/bspgetworkarea.c \
../../shared/bootcard.c ../../shared/sbrk.c \
- ../../shared/gnatinstallhandler.c ../../shared/bsppretaskinghook.c \
- ../../shared/bspclean.c ../../shared/bspreset.c \
- startup/bspstart.c startup/memmap.c
-startup_rel_CPPFLAGS = $(AM_CPPFLAGS)
-startup_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-noinst_PROGRAMS += console.rel
-console_rel_SOURCES = console/uarts.c ../../shared/console.c
-console_rel_CPPFLAGS = $(AM_CPPFLAGS)
-console_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
+ ../../shared/gnatinstallhandler.c ../../shared/bsppretaskinghook.c \
+ ../../shared/bspclean.c \
+ startup/bspstart.c startup/memmap.c
+#console
+libbsp_a_SOURCES += console/uarts.c ../../shared/console.c
+#abort
+libbsp_a_SOURCES += ../shared/abort/abort.c
-noinst_PROGRAMS += abort.rel
-abort_rel_SOURCES = ../shared/abort/abort.c
-abort_rel_CPPFLAGS = $(AM_CPPFLAGS)
-abort_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-noinst_LIBRARIES = libbsp.a
-libbsp_a_SOURCES =
-libbsp_a_LIBADD = startup.rel console.rel abort.rel
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
+libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/clock.rel \
../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/timer.rel \
../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/ffuart.rel \
Index: c/src/lib/libbsp/arm/gumstix/bsp_specs
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/bsp_specs,v
diff -u -r1.1 bsp_specs
--- c/src/lib/libbsp/arm/gumstix/bsp_specs 4 Jun 2009 16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/bsp_specs 14 Jun 2009 12:05:47 -0000
@@ -4,10 +4,10 @@
*startfile:
%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s}}
+%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
*link:
-%{!qrtems: %(old_link)} %{qrtems: -Qy -dp -Bstatic -N -e _start}
+%{!qrtems: %(old_link)} %{qrtems: -dp -Bstatic -N}
*endfile:
%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
Index: c/src/lib/libbsp/arm/gumstix/start/start.S
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/start/start.S,v
diff -u -r1.1 start.S
--- c/src/lib/libbsp/arm/gumstix/start/start.S 4 Jun 2009 16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/start/start.S 14 Jun 2009 12:05:47 -0000
@@ -1,6 +1,6 @@
* By Yang Xi <hiyangxi at gmail.com>.
- * Based upon CSB336
+ * Based upon CSB337
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
Index: c/src/lib/libbsp/arm/gumstix/startup/bspstart.c
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/arm/gumstix/startup/bspstart.c,v
diff -u -r1.1 bspstart.c
--- c/src/lib/libbsp/arm/gumstix/startup/bspstart.c 4 Jun 2009
16:23:11 -0000 1.1
+++ c/src/lib/libbsp/arm/gumstix/startup/bspstart.c 14 Jun 2009 12:05:47 -0000
@@ -43,3 +43,11 @@
* can override the actual bsp_start routine used.
void bsp_start (void) __attribute__ ((weak, alias("bsp_start_default")));
+void bsp_reset( void )
+#if ON_SKYEYE == 1
+ SKYEYE_MAGIC_ADDRESS = 0xff;
+#endif
Index: c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c,v
retrieving revision 1.2
diff -u -r1.2 ffuart.c
--- c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c 5 Jun 2009 22:10:42 -0000 1.2
+++ c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c 14 Jun 2009 12:05:55 -0000
@@ -20,6 +20,7 @@
#include <libchip/sersupp.h>
volatile int dbg_dly;
+void _start(void);
/* static function prototypes */
static int ffuart_first_open(int major, int minor, void *arg);
@@ -126,6 +127,7 @@
c = (char) buf[i];
+#if ON_SKYEYE != 1
if(c=='\n'){
ffuart->rbr = '\r';
for (x = 0; x < 100; x++) {
@@ -136,8 +138,8 @@
break;
- ffuart->rbr = c;
+#endif
ffuart->rbr = c;
/* the TXRDY flag does not seem to update right away (is this true?) */
Index: c/src/lib/libcpu/arm/pxa255/include/pxa255.h
RCS file: /usr1/CVS/rtems/c/src/lib/libcpu/arm/pxa255/include/pxa255.h,v
diff -u -r1.1 pxa255.h
--- c/src/lib/libcpu/arm/pxa255/include/pxa255.h 4 Jun 2009 16:33:31 -0000 1.1
+++ c/src/lib/libcpu/arm/pxa255/include/pxa255.h 14 Jun 2009 12:05:56 -0000
@@ -86,8 +86,7 @@
#define FFUART_BASE 0x40100000
-/*Write the MAGIC_NUMBER to the MAGIC_ADDRESS then the Skyeye will exit,
- we can use this function to automatic test the RTEMS bsp */
+/*Write to KSYEYE_MAGIC_ADDRESS makes SKYEYE to exits*/
#define SKYEYE_MAGIC_ADDRESS (*(volatile word_t *)(0xb0000000))
#define SKYEYE_MAGIC_NUMBER (0xf0f0f0f0)
