[GSOC2009] gcc-testing gumstix support
xi yang hiyangxi at gmail.com
Sun Jun 14 12:15:18 UTC 2009
This patch is for skyeye:
Index: device/nandflash/nandflash_smallblock.c
--- device/nandflash/nandflash_smallblock.c	(revision 653)
+++ device/nandflash/nandflash_smallblock.c	(working copy)
@@ -516,7 +516,7 @@
 #endif
 	nf->writebuffer=(u8*)malloc(dev->pagedumpsize);
 	//nf->memsize=528*32*4096;
-       if ((nf->fdump= open(dev->dump, FILE_FLAG)) < 0)
+	if ((nf->fdump= open(dev->dump, FILE_FLAG, FILE_MODE)) < 0)
        	free(nf);
        	printf("error open nandflash dump!\n");
Index: device/nandflash/nandflash_smallblock.h
--- device/nandflash/nandflash_smallblock.h	(revision 653)
+++ device/nandflash/nandflash_smallblock.h	(working copy)
@@ -27,6 +27,8 @@
 	#define FILE_FLAG   (O_RDWR | O_CREAT)
 #endif
+#define FILE_MODE (0x777)
 #if (defined(__MINGW32__) || defined(__BEOS__))
 	#define POSIX_SHARE_MEMORY_BROKEN
 #endif
Index: memory/ram.c
--- memory/ram.c	(revision 653)
+++ memory/ram.c	(working copy)
@@ -261,10 +261,10 @@
 	void * state;
 	switch(size){
 		case 8:
-			*(uint8_t *)value = (uint8_t)mem_read_byte (offset);
+			*value = (uint8_t)mem_read_byte (offset);
 			break;
 		case 16:
-			*(uint16_t *)value = (uint16_t)mem_read_halfword(offset);
+			*value = (uint16_t)mem_read_halfword(offset);
 			break;
 		case 32:
 			*value = mem_read_word(offset);
Index: arch/arm/common/armemu.c
--- arch/arm/common/armemu.c	(revision 653)
+++ arch/arm/common/armemu.c	(working copy)
@@ -676,7 +676,13 @@
 		io_do_cycle (state);
 		state->NumInstrs++;
+		if (skyeye_config.shutdown_device.status){
+			if (state->NumInstrs >= skyeye_config.shutdown_device.max_ins){
+				fprintf(stderr, "Shutdown_device:max_ins expired\n");
+				exit(2);
 #ifdef MODET
 		/* Provide Thumb instruction decoding. If the processor is in Thumb
 		   mode, then we can simply decode the Thumb instruction, and map it
@@ -5069,6 +5075,11 @@
 	MEM_STORE_LOG("WORD");
 	BUSUSEDINCPCN;
+	if(skyeye_config.shutdown_device.status){
+		if(address == skyeye_config.shutdown_device.shutdown_addr)
+			exit(0);
 #ifndef MODE32
 	if (DESTReg == 15)
 		state->Reg[15] = ECC | ER15INT | R15PC | EMODE;
Index: utils/config/skyeye_config.h
--- utils/config/skyeye_config.h	(revision 653)
+++ utils/config/skyeye_config.h	(working copy)
@@ -100,6 +100,21 @@
 } machine_config_t;
+ * If status of shutdown device is 1, when "shutdown_addr"
+ * (align on 8bytes) is written, SKYEYE simulator exits.
+ * If the number of executed instructions by skyeye simulator
+ * is bigger than "max_instructions", then skyeye return with
+ * value 2
+typedef struct shutdown_config
+	unsigned int status;
+	u32 shutdown_addr;
+	unsigned long long  max_ins;
+}shutdown_config_t;
 #define MAX_BANK 8
 #define MAX_STR  1024
@@ -183,6 +198,7 @@
 int do_dummy_option ();
 int do_arch_option ();
 int do_cpu_option ();
+int do_shutdown_option ();
 int do_mach_option ();
 int do_mem_bank_option ();
 int do_net_option ();
@@ -248,6 +264,7 @@
 	//mem_config_t mem;
 //chy 2003-09-12, now support more io banks
 //      ioaddr_config_t ioaddr; //used for ARMul_notIOaddr funciton
+	shutdown_config_t shutdown_device;
 	net_config_t net[NET_MAXNICNUM_PER_HOST];
 	uart_config_t uart;
 	log_config_t log;
@@ -280,10 +297,12 @@
 	{"arch", do_arch_option, 0, 1},
 	{"cpu", do_cpu_option, 0, 1},
 	{"mach", do_mach_option, 0, 1},
+	{"shutdown_device", do_shutdown_option,0, 1},
 	/*mem option */
 	{"mem_bank", do_mem_bank_option, 0, MAX_BANK},
 	{"net", do_net_option, 0, 10},
 	{"energy", do_energy_option, 0, 1},
 	{"uart", do_uart_option, 0, MAX_UART_DEVICE_NUM},
Index: utils/config/skyeye_options.c
--- utils/config/skyeye_options.c	(revision 653)
+++ utils/config/skyeye_options.c	(working copy)
@@ -79,6 +79,9 @@
 	config->uart.count = 0;
 	atexit(skyeye_uart_cleanup);
+	config->shutdown_device.status = 0;
+	config->shutdown_device.max_ins = 0;
 	/*ywc 2005-04-01 */
 	config->no_dbct = 1;	/*default, dbct is off */
 	//teawater add for new tb manage function
2005.07.10----------------------------
@@ -247,6 +250,49 @@
 int
+do_shutdown_option (skyeye_option_t * this_option, int num_params,
+		const char *params[])
+	int ret;
+	char *value;
+	shutdown_config_t *shutdown = &(skyeye_config.shutdown_device);
+	if(ret = strncmp(params[0],"addr=",5)){
+		SKYEYE_ERR ("Error, Wrong parameter for shutdown_device\n");
+		return -1;
+	value = &(params[0][5]);
+	if(value[0]=='0' && (value[1] == 'x' || value[1] == 'X'))
+		shutdown->shutdown_addr = (unsigned int)strtoul(value,NULL,16);
+	else
+		shutdown->shutdown_addr = (unsigned int)strtoul(value,NULL,10);
+	if(shutdown->shutdown_addr & 0x7){
+		SKYEYE_ERR ("Error, shutdown address needs align on 8 bytes\n");
+		return -1;
+	if(ret = strncmp(params[1],"max_ins=",8)){
+		return -1;
+	value = &(params[1][8]);
+		shutdown->max_ins = strtoull(value,NULL,16);
+	else
+		shutdown->max_ins = strtoull(value,NULL,10);
+	if(shutdown->max_ins == 0){
+		SKYEYE_ERR ("Error, max_ins of shutdown device must greater than zero\n");
+		return -1;
+	shutdown->status = 1;
+	printf("Shutdown addr=%x, max_ins=%x\n",shutdown->shutdown_addr,
shutdown->max_ins);
+	return 1;
+int
 do_mem_bank_option (skyeye_option_t * this_option, int num_params,
