Newbie to RTEMS: ADA support issue
Ángel
leadzeppelin at gmail.com
Wed Jun 17 14:54:45 UTC 2009
Thank you, Joel.
The install process finished with no errors with --disable-tests and
--disable-docs options.
I am trying to compile the hello_world_ada sample without sucess:
~/RTEMS/ada-examples/hello_world_ada$ make
i386-rtems4.10-gnatmake -g -v \
-I/opt/rtems-4.10/i386-rtems4.10/pc386/lib/include/adainclude \
-O -gnata -gnatE -gnato -g hello -o hello.exe \
-bargs -Mgnat_main \
-largs -B/opt/rtems-4.10/i386-rtems4.10/pc386/lib/ -specs=bsp_specs
-qrtems -mtune=i386 -Dpc386 -Wl,-Ttext,0x00100000 \
rtems_init.o \
After installation, the /opt/rtems4.10/bin directory, which is in $PATH,
contains the following files:
rwxr-xr-x 2 root root 31214 2009-05-18 19:01 aclocal
-rwxr-xr-x 2 root root 31214 2009-05-18 19:01 aclocal-1.11
-rwxr-xr-x 1 root root 14642 2009-04-07 07:05 autoconf
-rwxr-xr-x 1 root root 8506 2009-04-07 07:05 autoheader
-rwxr-xr-x 1 root root 31811 2009-04-07 07:05 autom4te
-rwxr-xr-x 2 root root 257044 2009-05-18 19:01 automake
-rwxr-xr-x 2 root root 257044 2009-05-18 19:01 automake-1.11
-rwxr-xr-x 1 root root 20266 2009-04-07 07:05 autoreconf
-rwxr-xr-x 1 root root 17098 2009-04-07 07:05 autoscan
-rwxr-xr-x 1 root root 33799 2009-04-07 07:05 autoupdate
-rwxr-xr-x 1 root root 21323 2009-06-17 10:42 cklength
-rwxr-xr-x 1 root root 21359 2009-06-17 10:42 eolstrip
-rwxr-xr-x 1 root root 549352 2009-05-31 10:53 i386-rtems4.10-addr2line
-rwxr-xr-x 2 root root 573752 2009-05-31 10:53 i386-rtems4.10-ar
-rwxr-xr-x 2 root root 1007128 2009-05-31 10:53 i386-rtems4.10-as
-rwxr-xr-x 2 root root 197780 2009-05-31 22:14 i386-rtems4.10-c++
-rwxr-xr-x 1 root root 549160 2009-05-31 10:53 i386-rtems4.10-c++filt
-rwxr-xr-x 1 root root 196788 2009-05-31 22:14 i386-rtems4.10-cpp
-rwxr-xr-x 2 root root 197780 2009-05-31 22:14 i386-rtems4.10-g++
-rwxr-xr-x 2 root root 195096 2009-05-31 22:14 i386-rtems4.10-gcc
-rwxr-xr-x 2 root root 195096 2009-05-31 22:14 i386-rtems4.10-gcc-4.4.0
-rwxr-xr-x 1 root root 16412 2009-05-31 22:13 i386-rtems4.10-gccbug
-rwxr-xr-x 1 root root 27456 2009-05-31 22:14 i386-rtems4.10-gcov
-rwxr-xr-x 1 root root 2579296 2009-05-31 11:30 i386-rtems4.10-gdb
-rwxr-xr-x 1 root root 2579296 2009-05-31 11:30 i386-rtems4.10-gdbtui
-rwxr-xr-x 1 root root 611524 2009-05-31 10:53 i386-rtems4.10-gprof
-rwxr-xr-x 2 root root 836824 2009-05-31 10:53 i386-rtems4.10-ld
-rwxr-xr-x 2 root root 558932 2009-05-31 10:53 i386-rtems4.10-nm
-rwxr-xr-x 2 root root 706488 2009-05-31 10:53 i386-rtems4.10-objcopy
-rwxr-xr-x 2 root root 1034616 2009-05-31 10:53 i386-rtems4.10-objdump
-rwxr-xr-x 2 root root 573756 2009-05-31 10:53 i386-rtems4.10-ranlib
-rwxr-xr-x 1 root root 253788 2009-05-31 10:53 i386-rtems4.10-readelf
-rwxr-xr-x 1 root root 553444 2009-05-31 10:53 i386-rtems4.10-size
-rwxr-xr-x 1 root root 549352 2009-05-31 10:53 i386-rtems4.10-strings
-rwxr-xr-x 2 root root 706484 2009-05-31 10:53 i386-rtems4.10-strip
-rwxr-xr-x 1 root root 4060 2009-04-07 07:05 ifnames
-rwxr-xr-x 1 root root 3083 2009-06-17 10:42 install-if-change
-rwxr-xr-x 1 root root 26117 2009-06-17 10:42 packhex
-rwxr-xr-x 1 root root 19322 2009-06-17 10:42 rtems-bin2c
-rwxr-xr-x 1 root root 29155 2009-06-17 10:42 unhex
We can see that "i386-rtems4.10-gnatmake" is missing.
First of all, I installed GNAT in my computer. After that, installed the
prebuilt rpm packages from ftp. Finally, downloaded CVS - bootstrap - make
all - make install. I have compiled the hello world C example sucessfully,
but with the ADA version I have the problem I have explained.
Thanks for your help.
2009/6/15 Joel Sherrill <joel.sherrill at oarcorp.com>
> Ángel wrote:
>> Hi,
>> I have successfully installed the prebuilt tools set and downloaded the
>> CVS.
>> My problem is that the configure script does not recognize the
>> --enable-ada option, as indicated in
>> http://www.rtems.com/wiki/index.php/RTEMSAda:
>> I think the --enable-option-checking is making each "sub-configure"
> script
> tell you that it doesn't process that option. It really only means when
> you are
> in directory X, --enable-XYZ is being ignored. No big deal.
> --joel
> $ ../cvs/configure --target=i386-rtems4.10 --enable-rtemsbsp="pc386"
>> --enable-ada --enable-option-checking | grep WARNING
>> configure: WARNING: unrecognized options: --enable-ada
>> configure: WARNING: unrecognized options: --enable-rtemsbsp, --enable-ada
>> configure: WARNING: unrecognized options: --enable-ada,
>> --with-target-subdir
>> Without --enable-ada option I have successfully installed RTEMS and built
>> the C examples.
>> Thanks in advance.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20090617/19294566/attachment.html>
