gcc 4.3.2 vectorizes access to volatile array
Till Straumann
strauman at slac.stanford.edu
Mon Jun 22 14:47:39 UTC 2009
gcc-4.3.2 seems to produce bad code when
accessing an array of small 'volatile'
objects -- it may try to access multiple
such objects in a 'parallel' fashion.
E.g., instead of reading two consecutive
'volatile short's sequentially it reads
a single 32-bit longword. This may crash
e.g., when accessing a memory-mapped device
which allows only 16-bit accesses.
If I compile this code fragment
void volarrcpy(short *d, volatile short *s, int n)
int i;
for (i=0; i<n; i++)
d[i] = s[i];
with '-O3' (the critical option seems to be '-ftree-vectorize')
then gcc-4.3.2 produces quite complicated code
but the essential section is (powerpc)
.L7:
lhz 0,0(11)
addi 11,11,2
lwzx 0,4,9
stwx 0,3,9
addi 9,9,4
bdnz .L7
or i386
.L7:
movw (%ecx), %ax
movl (%esi,%edx,4), %eax
movl %eax, (%ebx,%edx,4)
incl %edx
addl $2, %ecx
cmpl %edx, -20(%ebp)
ja .L7
Disassembled back into C-code, this reads
uint32_t *dst_l = (uint32_t*)d;
uint32_t *src_l = (uint32_t*)s;
for (i=0; i<n/2; i++) {
d[i] = s[i];
dst_l[i] = src_l[i];
This code seems neither optimal nor correct.
Besides reading half of the locations twice
which violates the semantics of volatile
objects accessing such objects in a 'vectorized'
way (in this case: instead of reading
two adjacent short addresses gcc emits
a single 32-bit read) seems illegal to me.
Similar behavior seems to be present in 4.3.3.
Does anybody have some insight? Should I file
a bug report?
Regards
-- Till
PS: I'm not subscribed to the gcc mailing list;
please CC me on any replies, thanks.
