Debian-host build error...
Alexandre Constantino alexandre.constantino at edisoft.pt
Thu Jun 25 11:26:40 UTC 2009
Hi,
at this point I don't have much to add, since the cause of the problem was determined.
Ed, you are running some ancient version of Debian.
kernel 2.6.18 and libc6 2.3 (or older) are... old.
Upgrade your distro to the latest stable version of Debian and you should solve your problems.
I've been running Debian for a few years and it works fine (as good as a linux system can anyway ;))
Best regards,
Alexandre
On Thursday 25 June 2009, Ian Caddy wrote:
> Hi Ed,
> Now I am also not an expert in this but from what I could find:
> Depending on your version you might find that your latest version you
> can get of libc is 2.3 not the needed 2.4.
> What do you get from:
> apt-cache show libc6
> It should show you which version of glibc is installed.  I would guess
> that it is 2.3.<something> and this is causing your problems.
> Are you running the latest version of Debian?
> regards,
> Ian Caddy
> Ed Sutter wrote:
> > One more snippet of information...
> > I figured I'd test to see if the problem was blackfin-tools related, so
> > I installed the powerpc tools and got the exact same error...
> > els:powerpc-rtems4.10-gcc --help
> > powerpc-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not fou
> > nd (required by powerpc-rtems4.10-gcc)
> > Ed
> > Ed Sutter wrote:
> >> Daron & all,
> >> Yep, that was a typo.  The PATH is correct; however, I hadnt' actually
> >> tried the cross-compiler out manually, and there is an issue...
> >> Forget about successful cross-compilation, there are shared libs it
> >> can't find...
> >> els:bfin-rtems4.10-gcc --help
> >> bfin-rtems4.10-gcc: /lib/tls/i686/cmov/libc.so.6: version `GLIBC_2.4' not found
> >> (required by bfin-rtems4.10-gcc)
> >> A little googling seems to indicate that this is a strange issue with Debian
> >> because it happens with other tools.  Haven't figured out how to get around it
> >> though.
> >> Ed
> >> Daron Chabot wrote:
> >>> Hi Ed,
> >>> Have not used alien to convert rpms to debs, but:
> >>> Have you verified that your cross-compiler works ? You should get an
> >>> "a.out" file from cross-compiling this:
> >>>     int foo(void) { return 0; }
> >>> Also, I noticed you specified "export PATH=/opt/rtems-4.9/bin:$PATH"...
> >>> i assume the "rtems-4.9" was simply a typo, and your path actually
> >>> points to the correct tool versions...
> >>> -- dc
> >>> On Wed, Jun 24, 2009 at 12:46 PM, Ed Sutter <esutter at alcatel-lucent.com
> >>> <mailto:esutter at alcatel-lucent.com>> wrote:
> >>>     Ian,
> >>>     Thanks, here's more info...
> >>>     I'm following the steps from the "Quick Start" wiki page.
> >>>     First I got the prebuilt tools from:
> >>>       http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
> >>>     I followed the Debian-specific instructions at:
> >>>       http://www.rtems.com/wiki/index.php/RTEMS_Prebuilt_Tools
> >>>     which talk about the "alien" tool and the conversion from .rpm to .deb.
> >>>     All that appears to work just fine.
> >>>     Then, referring to the "Example Application Compiling" page
> >>>     I execute these steps...
> >>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
> >>>      cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P rtems
> >>>      cd rtems
> >>>      ./bootstrap
> >>>      cd ..
> >>>      mkdir bf537Stamp
> >>>      cd bf537Stamp
> >>>      ../rtems/configure --target=bfin-rtems4.10
> >>>     --enable-rtemsbsp=bf537Stamp \
> >>>        --enable-tests=samples --disable-posix --disable-itron
> >>>      make all
> >>>     The error occurs in the "make all" step.  It apparently runs yet another
> >>>     configure down below, and that's the point where it chokes.  Attached
> >>>     is the output of the "make all", as well as the config.log file that the
> >>>     error in the make output is referring to.
> >>>     Thanks for any help you can offer!  I'm bracing myself for being told
> >>>     I'm doing something really stupid.  :-(
> >>>     Ed
> >>>     Ian Caddy wrote:
> >>>         Hi Ed,
> >>>         I am not really sure, but do you have any more details?
> >>>         Such as when the error occurred, I assume during configure?
> >>>         If so, did you look at the config.log output to see if it gave
> >>>         any clues as to why it failed the check for being able to build
> >>>         executables?
> >>>         regards,
> >>>         Ian Caddy
> >>>         Ed Sutter wrote:
> >>>             Folks,
> >>>             Didn't get any responses on this, so I figured I'd try again...
> >>>             When I reported this error, I was using pre-built tools from:
> >>>                http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
> >>>             then the other day I started over using:
> >>>             The exact same error occurred, so I'm still clueless.
> >>>             Even the "remotest" of suggestions at this point would not
> >>>             be in vain
> >>>             (yea, I'm begging) :-( otherwise, I suppose I have to hunt
> >>>             down a different
> >>>             Linux box (non-debian) to isolate this problem.
> >>>             Thanks,
> >>>             Ed
> >>>             Ed Sutter wrote:
> >>>                 Folks,
> >>>                 I'm walking through the quick-start procedure for
> >>>                 building the
> >>>                 BF537Stamp BSP.  My development host is Debian, and I've
> >>>                 gotten
> >>>                 to the point (on the quick-start page) where it mentions
> >>>                 the error:
> >>>                 * If you experience a "C compiler cannot create
> >>>                 executables" error,
> >>>                 * try fixing your compiler by getting libc-dev
> >>>                 I ran apt-get install libc-dev and got the following
> >>>                 message:
> >>>                 * root:apt-get install libc-dev
> >>>                 * Reading package lists... Done
> >>>                 * Building dependency tree... Done
> >>>                 * Note, selecting libc6-dev instead of libc-dev
> >>>                 * libc6-dev is already the newest version.
> >>>                 * 0 upgraded, 0 newly installed, 0 to remove and 1 not
> >>>                 upgraded.
> >>>                 Anyone working with a Debian host that has had (and
> >>>                 overcame) this
> >>>                 problem?
> >>>                 Thanks
> >>>                 Ed
> >>>                 _______________________________________________
> >>>                 rtems-users mailing list
> >>>                 rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> >>>                 http://www.rtems.org/mailman/listinfo/rtems-users
> >>>             No virus found in this incoming message.
> >>>             Checked by AVG - www.avg.com <http://www.avg.com> Version:
> >>>             8.5.375 / Virus Database: 270.12.90/2198 - Release Date:
> >>>             06/23/09 17:54:00
> >>>     This file contains any messages produced by compilers while
> >>>     running configure, to aid debugging if configure makes a mistake.
> >>>     It was created by rtems-c configure 4.9.99.0, which was
> >>>     generated by GNU Autoconf 2.63.  Invocation command line was
> >>>      $ ../../../rtems/c/configure --prefix=/opt/rtems-4.10
> >>>     --host=bfin-rtems4.10 --build=i686-pc-linux-gnu
> >>>     --target=bfin-rtems4.10 --enable-rtemsbsp=bf537Stamp
> >>>     --with-target-subdir=bfin-rtems4.10
> >>>     --exec-prefix=/opt/rtems-4.10/bfin-rtems4.10
> >>>     --includedir=/opt/rtems-4.10/bfin-rtems4.10/include
> >>>     --cache-file=/dev/null --srcdir=../../../rtems/c
> >>>     ## Platform. ##
> >>>     hostname = xpcelslinux1
> >>>     uname -m = i686
> >>>     uname -r = 2.6.18-6-486
> >>>     uname -s = Linux
> >>>     uname -v = #1 Mon May 4 23:59:22 UTC 2009
> >>>     /usr/bin/uname -p = unknown
> >>>     /bin/uname -X     = unknown
> >>>     /bin/arch              = i686
> >>>     /usr/bin/arch -k       = unknown
> >>>     /usr/convex/getsysinfo = unknown
> >>>     /usr/bin/hostinfo      = unknown
> >>>     /bin/machine           = unknown
> >>>     /usr/bin/oslevel       = unknown
> >>>     /bin/universe          = unknown
> >>>     PATH: /home/els/bin
> >>>     PATH: /usr/local/bin
> >>>     PATH: /usr/bin
> >>>     PATH: /bin
> >>>     PATH: /usr/games
> >>>     PATH: /home/els/bin
> >>>     PATH: /sbin
> >>>     PATH: /opt/uClinux/bfin-elf/bin
> >>>     PATH: /opt/uClinux/bfin-uclinux/bin
> >>>     PATH: /opt/uClinux/bfin-linux-uclibc/bin
> >>>     PATH: /opt/arm-2007q3/bin
> >>>     PATH: /opt/rtems-4.10/bin
> >>>     ## Core tests. ##
> >>>     configure:1821: checking for gmake
> >>>     configure:1851: result: no
> >>>     configure:1821: checking for make
> >>>     configure:1837: found /usr/bin/make
> >>>     configure:1848: result: make
> >>>     configure:1873: checking for RTEMS Version
> >>>     configure:1875: result: 4.9.99.0
> >>>     configure:1885: checking build system type
> >>>     configure:1903: result: i686-pc-linux-gnu
> >>>     configure:1925: checking host system type
> >>>     configure:1940: result: bfin-unknown-rtems4.10
> >>>     configure:1963: checking target system type
> >>>     configure:1978: result: bfin-unknown-rtems4.10
> >>>     configure:2006: checking rtems target cpu
> >>>     configure:2029: result: bfin
> >>>     configure:2049: checking for a BSD-compatible install
> >>>     configure:2117: result: /usr/bin/install -c
> >>>     configure:2128: checking whether build environment is sane
> >>>     configure:2171: result: yes
> >>>     configure:2196: checking for a thread-safe mkdir -p
> >>>     configure:2235: result: /bin/mkdir -p
> >>>     configure:2248: checking for gawk
> >>>     configure:2278: result: no
> >>>     configure:2248: checking for mawk
> >>>     configure:2264: found /usr/bin/mawk
> >>>     configure:2275: result: mawk
> >>>     configure:2286: checking whether make sets $(MAKE)
> >>>     configure:2308: result: yes
> >>>     configure:2379: checking for bfin-rtems4.10-strip
> >>>     configure:2395: found /opt/rtems-4.10/bin/bfin-rtems4.10-strip
> >>>     configure:2406: result: bfin-rtems4.10-strip
> >>>     configure:2483: checking whether to enable maintainer-specific
> >>>     portions of Makefiles
> >>>     configure:2492: result: no
> >>>     configure:2593: checking for bf537Stamp.cfg
> >>>     configure:2607: result: ../../../rtems/c/../make/custom/bf537Stamp.cfg
> >>>     configure:2899: creating ./config.status
> >>>     ## Running config.status. ##
> >>>     This file was extended by rtems-c config.status 4.9.99.0, which was
> >>>      CONFIG_FILES    =
> >>>      CONFIG_HEADERS  =
> >>>      CONFIG_LINKS    =
> >>>      CONFIG_COMMANDS =
> >>>      $ ./config.status
> >>>     on xpcelslinux1
> >>>     config.status:690: creating Makefile
> >>>     ## Cache variables. ##
> >>>     ac_cv_build=i686-pc-linux-gnu
> >>>     ac_cv_env_build_alias_set=set
> >>>     ac_cv_env_build_alias_value=i686-pc-linux-gnu
> >>>     ac_cv_env_host_alias_set=set
> >>>     ac_cv_env_host_alias_value=bfin-rtems4.10
> >>>     ac_cv_env_target_alias_set=set
> >>>     ac_cv_env_target_alias_value=bfin-rtems4.10
> >>>     ac_cv_host=bfin-unknown-rtems4.10
> >>>     ac_cv_path_install='/usr/bin/install -c'
> >>>     ac_cv_path_mkdir=/bin/mkdir
> >>>     ac_cv_prog_AWK=mawk
> >>>     ac_cv_prog_MAKE=make
> >>>     ac_cv_prog_STRIP=bfin-rtems4.10-strip
> >>>     ac_cv_prog_make_make_set=yes
> >>>     ac_cv_target=bfin-unknown-rtems4.10
> >>>     ## Output variables. ##
> >>>     ACLOCAL='${SHELL} /home/els/rtems/rtems/missing --run aclocal-1.10'
> >>>     AMTAR='${SHELL} /home/els/rtems/rtems/missing --run tar'
> >>>     AUTOCONF='${SHELL} /home/els/rtems/rtems/missing --run autoconf'
> >>>     AUTOHEADER='${SHELL} /home/els/rtems/rtems/missing --run autoheader'
> >>>     AUTOMAKE='${SHELL} /home/els/rtems/rtems/missing --run automake-1.10'
> >>>     AWK='mawk'
> >>>     CYGPATH_W='echo'
> >>>     DEFS='-DPACKAGE_NAME=\"rtems-c\" -DPACKAGE_TARNAME=\"rtems-c\"
> >>>     -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c\
> >>>     4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\"'
> >>>     ECHO_C=''
> >>>     ECHO_N='-n'
> >>>     ECHO_T=''
> >>>     INSTALL_DATA='${INSTALL} -m 644'
> >>>     INSTALL_PROGRAM='${INSTALL}'
> >>>     INSTALL_SCRIPT='${INSTALL}'
> >>>     INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
> >>>     LIBOBJS=''
> >>>     LIBS=''
> >>>     LTLIBOBJS=''
> >>>     MAINT='#'
> >>>     MAINTAINER_MODE_FALSE=''
> >>>     MAINTAINER_MODE_TRUE='#'
> >>>     MAKE='make'
> >>>     MAKEINFO='${SHELL} /home/els/rtems/rtems/missing --run makeinfo'
> >>>     MKDIR_P='/bin/mkdir -p'
> >>>     PACKAGE='rtems-c'
> >>>     PACKAGE_BUGREPORT='http://www.rtems.org/bugzilla'
> >>>     PACKAGE_NAME='rtems-c'
> >>>     PACKAGE_STRING='rtems-c 4.9.99.0'
> >>>     PACKAGE_TARNAME='rtems-c'
> >>>     PACKAGE_VERSION='4.9.99.0'
> >>>     PATH_SEPARATOR=':'
> >>>     PROJECT_ROOT='../$(top_builddir)'
> >>>     PROJECT_TOPdir='../../$(top_builddir)'
> >>>     RTEMS_BSP_LIST=' bf537Stamp'
> >>>     RTEMS_CPU='bfin'
> >>>     RTEMS_TOPdir='..'
> >>>     SET_MAKE=''
> >>>     SHELL='/bin/sh'
> >>>     STRIP='bfin-rtems4.10-strip'
> >>>     VERSION='4.9.99.0'
> >>>     am__isrc=' -I$(srcdir)'
> >>>     am__leading_dot='.'
> >>>     am__tar='${AMTAR} chof - "$$tardir"'
> >>>     am__untar='${AMTAR} xf -'
> >>>     bindir='${exec_prefix}/bin'
> >>>     build='i686-pc-linux-gnu'
> >>>     build_alias='i686-pc-linux-gnu'
> >>>     build_cpu='i686'
> >>>     build_os='linux-gnu'
> >>>     build_vendor='pc'
> >>>     datadir='${datarootdir}'
> >>>     datarootdir='${prefix}/share'
> >>>     docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
> >>>     dvidir='${docdir}'
> >>>     exec_prefix='/opt/rtems-4.10/bfin-rtems4.10'
> >>>     host='bfin-unknown-rtems4.10'
> >>>     host_alias='bfin-rtems4.10'
> >>>     host_cpu='bfin'
> >>>     host_os='rtems4.10'
> >>>     host_vendor='unknown'
> >>>     htmldir='${docdir}'
> >>>     includedir='/opt/rtems-4.10/bfin-rtems4.10/include'
> >>>     infodir='${datarootdir}/info'
> >>>     install_sh='$(SHELL) /home/els/rtems/rtems/install-sh'
> >>>     libdir='${exec_prefix}/lib'
> >>>     libexecdir='${exec_prefix}/libexec'
> >>>     localedir='${datarootdir}/locale'
> >>>     localstatedir='${prefix}/var'
> >>>     mandir='${datarootdir}/man'
> >>>     mkdir_p='/bin/mkdir -p'
> >>>     oldincludedir='/usr/include'
> >>>     pdfdir='${docdir}'
> >>>     prefix='/opt/rtems-4.10'
> >>>     program_transform_name='s&^&bfin-rtems4.10-&'
> >>>     psdir='${docdir}'
> >>>     rtems_bsp_configure='../../../../rtems/c/src/configure
> >>>      '\''--prefix=/opt/rtems-4.10'\'' '\''--host=bfin-rtems4.10'\''
> >>>     '\''--build=i686-pc-linux-gnu'\'' '\''--target=bfin-rtems4.10'\''
> >>>     '\''--enable-tests=samples'\'' '\''--disable-posix'\''
> >>>     '\''--disable-itron'\'' '\''--with-target-subdir=bfin-rtems4.10'\''
> >>>     '\''--exec-prefix=/opt/rtems-4.10/bfin-rtems4.10'\''
> >>>     '\''--includedir=/opt/rtems-4.10/bfin-rtems4.10/include'\''
> >>>     '\''build_alias=i686-pc-linux-gnu'\''
> >>>     '\''host_alias=bfin-rtems4.10'\''
> >>>     '\''target_alias=bfin-rtems4.10'\''
> >>>     '\''--with-project-root=../../'\'' '\''--with-project-top=../../'\'''
> >>>     sbindir='${exec_prefix}/sbin'
> >>>     sharedstatedir='${prefix}/com'
> >>>     sysconfdir='${prefix}/etc'
> >>>     target='bfin-unknown-rtems4.10'
> >>>     target_alias='bfin-rtems4.10'
> >>>     target_cpu='bfin'
> >>>     target_os='rtems4.10'
> >>>     target_vendor='unknown'
> >>>     ## confdefs.h. ##
> >>>     #define PACKAGE_NAME "rtems-c"
> >>>     #define PACKAGE_TARNAME "rtems-c"
> >>>     #define PACKAGE_VERSION "4.9.99.0"
> >>>     #define PACKAGE_STRING "rtems-c 4.9.99.0"
> >>>     #define PACKAGE_BUGREPORT "http://www.rtems.org/bugzilla"
> >>>     configure: exit 0
> >>>     Making all in make
> >>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/make'
> >>>     make[1]: Nothing to be done for `all'.
> >>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/make'
> >>>     Making all in tools/build
> >>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
> >>>     make  all-am
> >>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/build'
> >>>     gcc -DHAVE_CONFIG_H -I. -I../../../rtems/tools/build     -g -O2 -MT
> >>>     cklength.o -MD -MP -MF .deps/cklength.Tpo -c -o cklength.o
> >>>     ../../../rtems/tools/build/cklength.c
> >>>     mv -f .deps/cklength.Tpo .deps/cklength.Po
> >>>     gcc  -g -O2   -o cklength cklength.o
> >>>     eolstrip.o -MD -MP -MF .deps/eolstrip.Tpo -c -o eolstrip.o
> >>>     ../../../rtems/tools/build/eolstrip.c
> >>>     mv -f .deps/eolstrip.Tpo .deps/eolstrip.Po
> >>>     gcc  -g -O2   -o eolstrip eolstrip.o
> >>>     packhex.o -MD -MP -MF .deps/packhex.Tpo -c -o packhex.o
> >>>     ../../../rtems/tools/build/packhex.c
> >>>     mv -f .deps/packhex.Tpo .deps/packhex.Po
> >>>     gcc  -g -O2   -o packhex packhex.o
> >>>     unhex.o -MD -MP -MF .deps/unhex.Tpo -c -o unhex.o
> >>>     ../../../rtems/tools/build/unhex.c
> >>>     mv -f .deps/unhex.Tpo .deps/unhex.Po
> >>>     gcc  -g -O2   -o unhex unhex.o
> >>>     rtems-bin2c.o -MD -MP -MF .deps/rtems-bin2c.Tpo -c -o rtems-bin2c.o
> >>>     ../../../rtems/tools/build/rtems-bin2c.c
> >>>     mv -f .deps/rtems-bin2c.Tpo .deps/rtems-bin2c.Po
> >>>     gcc  -g -O2   -o rtems-bin2c rtems-bin2c.o
> >>>     binpatch.o -MD -MP -MF .deps/binpatch.Tpo -c -o binpatch.o
> >>>     ../../../rtems/tools/build/binpatch.c
> >>>     mv -f .deps/binpatch.Tpo .deps/binpatch.Po
> >>>     gcc  -g -O2   -o binpatch binpatch.o
> >>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
> >>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/build'
> >>>     Making all in tools/cpu
> >>>     make[1]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
> >>>     Making all in generic
> >>>     `/home/els/rtems/bf537Stamp/tools/cpu/generic'
> >>>     make[2]: Nothing to be done for `all'.
> >>>     make[2]: Entering directory `/home/els/rtems/bf537Stamp/tools/cpu'
> >>>     make[2]: Nothing to be done for `all-am'.
> >>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
> >>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/tools/cpu'
> >>>     Making all in testsuites/tools
> >>>     `/home/els/rtems/bf537Stamp/testsuites/tools'
> >>>     `/home/els/rtems/bf537Stamp/testsuites/tools/generic'
> >>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
> >>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/testsuites/tools'
> >>>     Making all in bfin-rtems4.10/c
> >>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
> >>>     Making all in .
> >>>     Configuring RTEMS_BSP=bf537Stamp
> >>>     checking for gmake... no
> >>>     checking for make... make
> >>>     checking build system type... i686-pc-linux-gnu
> >>>     checking host system type... bfin-unknown-rtems4.10
> >>>     checking rtems target cpu... bfin
> >>>     checking for a BSD-compatible install... /usr/bin/install -c
> >>>     checking whether build environment is sane... yes
> >>>     checking for a thread-safe mkdir -p... /bin/mkdir -p
> >>>     checking for gawk... no
> >>>     checking for mawk... mawk
> >>>     checking whether make sets $(MAKE)... yes
> >>>     checking for bfin-rtems4.10-strip... bfin-rtems4.10-strip
> >>>     checking whether to enable maintainer-specific portions of
> >>>     Makefiles... no
> >>>     checking for RTEMS_BSP... bf537Stamp
> >>>     checking for
> >>>     ../../../../rtems/c/src/../../bspkit/bfin/*/cfg/bf537Stamp.cfg... no
> >>>     checking for
> >>>     ../../../../rtems/c/src/../../make/custom/bf537Stamp.cfg... yes
> >>>     checking whether BSP supports networking... yes
> >>>     checking whether CPU supports libposix... disabled
> >>>     configure: setting up make/custom
> >>>     checking for
> >>>     checking for
> >>>     configure: creating make/bf537Stamp.cache
> >>>     make[3]: Entering directory
> >>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp'
> >>>     make[3]: Leaving directory
> >>>     checking for RTEMS_CPU_MODEL... bf537
> >>>     checking for RTEMS_BSP_FAMILY... (cached) bf537Stamp
> >>>     checking for CPU_CFLAGS... (cached)
> >>>     checking for CFLAGS_OPTIMIZE_V... (cached) -O2 -g
> >>>     checking for style of include used by make... GNU
> >>>     checking for bfin-rtems4.10-gcc... bfin-rtems4.10-gcc
> >>>     checking for bfin-rtems4.10-gcc... (cached) bfin-rtems4.10-gcc
> >>>     checking for C compiler default output file name...
> >>>     configure: error: in
> >>>     `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c/bf537Stamp':
> >>>     configure: error: C compiler cannot create executables
> >>>     See `config.log' for more details.
> >>>     make[2]: *** [bf537Stamp] Error 1
> >>>     make[2]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
> >>>     make[1]: *** [all-recursive] Error 1
> >>>     make[1]: Leaving directory `/home/els/rtems/bf537Stamp/bfin-rtems4.10/c'
> >>>     make: *** [all-recursive] Error 1
